Dell Vostro 1400 Screen Replacement
    1. Dell Vostro 1400 Screen Replacement, Battery: step 1, image 1 of 1
      • Be sure the power is off and all cables are unplugged from the device before starting.
      • After flipping over the laptop, the battery is on the bottom side of the laptop.
      • Find the tabs on both the left and right side of the battery.
      Ask FixBot
    2. Dell Vostro 1400 Screen Replacement: step 2, image 1 of 1
      • Push tabs toward the outside of the laptop until they lock in place.
      Ask FixBot
    3. Dell Vostro 1400 Screen Replacement: step 3, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 3, image 2 of 2
      • Push the battery forward to eject it from the laptop.
      Ask FixBot
    1. Dell Vostro 1400 Screen Replacement, Screen: step 4, image 1 of 1
      • Please make sure your device is completely turned off and everything is unplugged from the device
      • Open the laptop.
      Ask FixBot
    2. Dell Vostro 1400 Screen Replacement: step 5, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 5, image 2 of 2
      • Remove the 6 screw hole covers surrounding the screen.
      • Remove the 6 screws that were underneath the screw covers.
      Ask FixBot
    3. Dell Vostro 1400 Screen Replacement: step 6, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 6, image 2 of 2
      • Carefully remove the plastic surrounding the screen by pulling off, starting at the bottom.
      • Remove the two (2.5mm x 5mm) screws at the top, by the camera.
      Ask FixBot
    4. Dell Vostro 1400 Screen Replacement: step 7, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 7, image 2 of 2
      • Remove the two 5mm screws from the camera above the screen.
      • Remove the two 5mm screws from the bottom of the screen.
      Ask FixBot
    5. Dell Vostro 1400 Screen Replacement: step 8, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 8, image 2 of 2
      • Carefully remove the screen from the back cover.
      Ask FixBot
    6. Dell Vostro 1400 Screen Replacement: step 9, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 9, image 2 of 2
      • Lift up the black tag holding the camera and cable together.
      • Unplug the camera from the cable.
      Ask FixBot
    7. Dell Vostro 1400 Screen Replacement: step 10, image 1 of 3 Dell Vostro 1400 Screen Replacement: step 10, image 2 of 3 Dell Vostro 1400 Screen Replacement: step 10, image 3 of 3
      • Unplug the two cables connected to the screen.
      Ask FixBot
    8. Dell Vostro 1400 Screen Replacement: step 11, image 1 of 2 Dell Vostro 1400 Screen Replacement: step 11, image 2 of 2
      • Remove the six 3mm screws on each side of the screen.
      • Remove the railing on each side of the screen.
      • The railing will be marked "L" for left side or "R" for the right. This should assist in reassembly.
      Ask FixBot
2 other people completed this guide.
David Hogg
739 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 110
All Time: 1,020
