Up to 20% off select tools
Dell Vostro 1400 RAM Replacement
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
95
All Time:
1,013
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Steps on how to take out and replace the RAM drive. Follow these steps for the easiest possible way to take out and replace the RAM drive.
    1. Dell Vostro 1400 RAM Replacement, Battery: step 1, image 1 of 1
      • Be sure the power is off and all cables are unplugged from the device before starting.
      • After flipping over the laptop, the battery is on the bottom side of the laptop.
      • Find the tabs on both the left and right side of the battery.
      Ask FixBot
    2. Dell Vostro 1400 RAM Replacement: step 2, image 1 of 1
      • Push tabs toward the outside of the laptop until they lock in place.
      Ask FixBot
    3. Dell Vostro 1400 RAM Replacement: step 3, image 1 of 2 Dell Vostro 1400 RAM Replacement: step 3, image 2 of 2
      • Push the battery forward to eject it from the laptop.
      Ask FixBot
    1. Dell Vostro 1400 RAM Replacement, RAM: step 4, image 1 of 2 Dell Vostro 1400 RAM Replacement, RAM: step 4, image 2 of 2
      • Make sure the laptop is turned off and all cables are unplugged.
      • Loosen the three 3 mm screws on the RAM cover.
      • Screws will not completely come out.
      • Lift the cover and remove it from the laptop.
      Ask FixBot
    2. Dell Vostro 1400 RAM Replacement: step 5, image 1 of 2 Dell Vostro 1400 RAM Replacement: step 5, image 2 of 2
      • Pull tabs apart on both the top and bottom of the memory card.
      • Lift memory card and remove it from the laptop.
      • Repeat the process for the second memory card.
      Ask FixBot
Author
with
David Hogg
739 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 95
All Time: 1,013
