Up to 20% off select tools
Dell Vostro 1310 Memory Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
57
All Time:
602
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Vostro 1310 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the battery lock to the open position. {2}
      • Slide the battery latch release to the open position. (You may need to hold the latch release in the open position while removing the battery.){3}
      • Slide the battery out of the battery bay. {1}
      Ask FixBot
    1. Dell Vostro 1310 Memory Module Replacement, Memory Module: step 2, image 1 of 1
      • Remove the M2.5 x 5-mm screw that secures the memory cover, and remove the cover and set it aside.
      Ask FixBot
    2. Dell Vostro 1310 Memory Module Replacement: step 3, image 1 of 1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 57
All Time: 602
