Up to 20% off select tools
Dell Vostro 1000 Memory Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
58
All Time:
627
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Vostro 1000 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide and hold the battery-bay latch release on the bottom of the computer, and then lift the battery from the bay.
      Ask FixBot
    1. Dell Vostro 1000 Memory Module Replacement, Memory Module: step 2, image 1 of 1
      • loosen the captive screws on the memory module cover, and then remove the memory module cover.
      Ask FixBot
    2. Dell Vostro 1000 Memory Module Replacement: step 3, image 1 of 1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory-module securing clips.
      • NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Use your fingertips to carefully spread apart the memory-module securing clips on each end of the memory module connector until the module pops up.
      • Remove the module from the connector.
      Ask FixBot
2 other people completed this guide.
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 58
All Time: 627
