Introduction
Use this guide to replace the volume button assembly in the Dell Venue Pro.
The volume button is mounted internally and requires removing the back cover, battery, and motherboard to access it. This guide walks through the necessary steps to safely remove and replace the volume button assembly.
Before beginning, power off the phone and remove the back cover and battery.
Slide the back cover up.
Lift the back cover away from the device completely.
Use your finger to lift the battery using the notch in the upper left corner of the compartment.
Remove the Back Cover
Slide and lift the back cover off the phone. (Use the existing Back Cover Removal guide as reference)
Expose the Motherboard
With the midframe removed, the motherboard should now be fully visible.
Identify the following components before continuing:
SIM card reader near the top of the device
Metal shielding covering the center of the motherboard
Micro-USB charging port at the bottom
Secondary daughterboard connection on the left side
Set the midframe aside.
Remove the Motherboard
Starting from the top edge, gently lift the motherboard up and away from the phone housing.
The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
Once free, remove the motherboard from the device. Set the motherboard aside.
