Introduction
Use this guide to replace the motherboard in the Dell Venue Pro.
A damaged or malfunctioning charging port is a common reason for motherboard replacement, since the charging port is integrated into the main logic board.
This is an advanced repair that requires removing several internal components. Before beginning, power off your device and remove the back cover and battery.
Slide the back cover up.
Lift the back cover away from the device completely.
Use your finger to lift the battery using the notch in the upper left corner of the compartment.
Use a Phillips #00 screwdriver to remove the 4.6 mm screws securing the midframe to the phone.
Expose the Motherboard
With the midframe removed, the motherboard should now be fully visible.
Identify the following components before continuing:
SIM card reader near the top of the device
Metal shielding covering the center of the motherboard
Micro-USB charging port at the bottom
Secondary daughterboard connection on the left side
Set the midframe aside.
Disconnect Ribbon Cables
At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
Use tweezers or a fingernail to gently lift the flex cable connectors straight up from their sockets. Disconnect the following cables:
Display cable
Any remaining flex cables attached to the motherboard
After reassembly, power on the device and confirm that it boots normally.
Plug in a charger to verify that the charging port functions correctly and that the device charges as expected.
