Dell Venue Pro Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
56
All Time:
284
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Introduction
Go to step 1 ↓
The Dell Venue Pro uses a portrait slide-out QWERTY keyboard located beneath the display assembly. If your keyboard buttons stop responding, keys stick, or the slider mechanism becomes misaligned, the keyboard assembly may need to be replaced.
This guide walks you through the steps required to remove the midframe, disconnect the keyboard flex cable, and install a new keyboard assembly.
Before beginning, power off your device and remove the back cover, battery, and SIM card.
Tools
    1. Dell Venue Pro Keyboard Replacement, Back Cover: step 1, image 1 of 1
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
      Ask FixBot
    1. Dell Venue Pro Keyboard Replacement, Battery: step 2, image 1 of 2 Dell Venue Pro Keyboard Replacement, Battery: step 2, image 2 of 2
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
      Ask FixBot
    1. Dell Venue Pro Keyboard Replacement, Dell Venue Pro Keyboard: step 3, image 1 of 2 Dell Venue Pro Keyboard Replacement, Dell Venue Pro Keyboard: step 3, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the screws securing the midframe.
      • Keep track of screw lengths. Mixing screws may damage the frame during reassembly.
      Ask FixBot
    2. Dell Venue Pro Keyboard Replacement: step 4, image 1 of 3 Dell Venue Pro Keyboard Replacement: step 4, image 2 of 3 Dell Venue Pro Keyboard Replacement: step 4, image 3 of 3
      • Detach the Midframe
      • Insert a plastic opening tool into the seam between the midframe and the phone body.
      • Work your way around the edges to release the clips.
      • Once all clips are disengaged, lift the midframe away from the device.
      • Do not force the midframe off continue working around stuck clips to avoid cracking the housing.
      Ask FixBot
    3. Dell Venue Pro Keyboard Replacement: step 5, image 1 of 1
      • Locate the Keyboard Flex Cable
      • -With the midframe removed, the motherboard and flex connectors will be visible. Find the keyboard ribbon cable it is a thin, wide flex cable running from the slider mechanism to the motherboard.
      • Use tweezers or a fingernail to flip up the locking tab on the keyboard ZIF connector.
      • Slide the keyboard flex cable straight out of the connector.
      • Disconnect the Keyboard Ribbon Cable : Use tweezers or a fingernail to lift the locking tab on the ZIF connector. Gently slide the ribbon cable out of the connector.
      • Do not pull on the flex cable by force; always release the locking tab first
      Ask FixBot
    4. Dell Venue Pro Keyboard Replacement: step 6, image 1 of 1
      • Remove the Slider Assembly Screws
      • The keyboard is attached to the slider mechanism beneath the display.
      • Use a Phillips #00 screwdriver to remove the 4 Phillips screws (≈ 2.0 mm length) securing the slider rails to the frame.
      • Set the screws aside and keep track of their locations for reassembly.
      • Screw count and exact placement may vary slightly depending on the device revision.
      Ask FixBot
    5. Dell Venue Pro Keyboard Replacement: step 7, image 1 of 1
      • Slide the Keyboard Assembly Out
      • Carefully push the slider rails forward to move the keyboard assembly out from beneath the display.
      • Once fully extended, lift the keyboard assembly away from the back of the display housing.
      • Do not force the assembly. If it does not slide smoothly, double-check that all screws securing the slider mechanism have been removed.
      Ask FixBot
    6. Dell Venue Pro Keyboard Replacement: step 8, image 1 of 2 Dell Venue Pro Keyboard Replacement: step 8, image 2 of 2
      • Remove the Keyboard from the Frame
      • Lift the keyboard assembly away from the bezel/frame.
      • If any screws remain attached to the keyboard or frame, remove them now.
      • Set the keyboard aside.
      Ask FixBot
After reassembly, power on the device and test the keyboard. Confirm that all letter keys, the space bar, and modifier keys respond correctly, and that the slider mechanism moves smoothly. If all functions operate normally, the repair is complete
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 284
