Dell Venue 8 Front Camera Replacement
    1. Dell Venue 8 Front Camera Replacement, Rear Case/Midframe: step 1, image 1 of 1
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
      Ask FixBot
    2. Dell Venue 8 Front Camera Replacement: step 2, image 1 of 3 Dell Venue 8 Front Camera Replacement: step 2, image 2 of 3 Dell Venue 8 Front Camera Replacement: step 2, image 3 of 3
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
      Ask FixBot
    1. Dell Venue 8 Front Camera Replacement, Front Camera: step 3, image 1 of 2 Dell Venue 8 Front Camera Replacement, Front Camera: step 3, image 2 of 2
      • The front-facing camera is located just above the rear-facing camera.
      • Pull the connection tab up, unclipping it.
      • Pull up on the front camera, and the adhesive will release.
      Ask FixBot
Andrea
1,071 Reputation
5 Guides authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 795
