Up to 20% off select tools
Dell Venue 8 Display Replacement
Views: 8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
95
All Time:
8,022
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Parts
Tools
Introduction
Go to step 1 ↓
If your screen is cracked, broken, doesn't respond to touch, or has broken pixels, it might be time to replace the screen. This guide will help you to replace the screen on the Dell Venue 8
    1. Dell Venue 8 Display Replacement, Rear Case/Midframe: step 1, image 1 of 1
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
      Ask FixBot
    2. Dell Venue 8 Display Replacement: step 2, image 1 of 3 Dell Venue 8 Display Replacement: step 2, image 2 of 3 Dell Venue 8 Display Replacement: step 2, image 3 of 3
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
      Ask FixBot
    1. Dell Venue 8 Display Replacement, Battery: step 3, image 1 of 1
      • Unclip the power clip from the motherboard by pulling down gently towards the bottom of the tablet.
      Ask FixBot
    2. Dell Venue 8 Display Replacement: step 4, image 1 of 1
      • Gently pry the battery away from the device with the plastic opening tool to remove it.
      • The battery is held on to the tablet by a light adhesive
      Ask FixBot
    1. Dell Venue 8 Display Replacement, Speaker: step 5, image 1 of 1
      • Using your plastic opening tool, unclip the speaker connection from the logic board.
      • Caution: Pull directly up, not out, on the connection
      Ask FixBot
    2. Dell Venue 8 Display Replacement: step 6, image 1 of 1
      • Remove the speaker by placing using your plastic opening tool in the gap on the top of the speaker and prying it up.
      • The speaker is held on by light adhesive
      Ask FixBot
    1. Dell Venue 8 Display Replacement, Display: step 7, image 1 of 2 Dell Venue 8 Display Replacement, Display: step 7, image 2 of 2
      • Disconnect the display clip found next to the speaker.
      • Disconnect the Display connection located at the top of the tablet.
      Ask FixBot
    2. Dell Venue 8 Display Replacement: step 8, image 1 of 1
      • Unclip the logic board from the Display.
      Ask FixBot
7 other people completed this guide.
Author
with
Mitul
673 Reputation
1 Guide authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
72 Guides authored
2 Guide Comments
LOL. Who rated this as a difficult repair? Seriously? T5 screws too much for you? The only issue with the repair for this device is the adhesive between the digi and frame is a REAL pain to remove, and the plastic frame is likely to melt if you use too much/high heat. Otherwise, it's very simple. Just be careful when installing the new digi, as the motherboard needs to be slightly lifted to feed the connector.
Rene - Reply Share
Thanks for the instructions!
Is there a part 2 for this guide? The instructions is incomplete and doesn't not include steps to actually remove the digitizer.
Franklin Ramos - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 95
All Time: 8,022
