Up to 20% off select tools
Dell Venue 8 Back Camera Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
75
All Time:
1,591
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If your camera isnt functioning properly, not showing a display, or looks cracked or foggy, it may need to be replaced. In this guide we will be replacing the rear-facing camera.
    1. Dell Venue 8 Back Camera Replacement, Rear Case/Midframe: step 1, image 1 of 1
      • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
      • You will hear click sounds as the clips unhinge
      • Remove the back panel of the device.
      Ask FixBot
    2. Dell Venue 8 Back Camera Replacement: step 2, image 1 of 3 Dell Venue 8 Back Camera Replacement: step 2, image 2 of 3 Dell Venue 8 Back Camera Replacement: step 2, image 3 of 3
      • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
      • The silver screws are marked with an "S" or a sticker [S1.6(Silver)] See the corrected image
      • 4.45mm Silver screws
      • 3.6mm Black screws
      • Gently snap the perimeter clips open, and remove the internal plastic case.
      Ask FixBot
    1. Dell Venue 8 Back Camera Replacement, Back Camera: step 3, image 1 of 1
      • Use the plastic opening tool to disconnect the camera from the logic board, by prying it up.
      Ask FixBot
Author
with
Andrea
1,071 Reputation
5 Guides authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 75
All Time: 1,591
