Dell Venue 8 7840 Screen Replacement
    1. Dell Venue 8 7840 Screen Replacement, Screen: step 1, image 1 of 1
      • Make sure your device is turned off. Leaving it turned on may cause an electric shock.
      • Face the device with the screen towards you.
      Ask FixBot
    2. Dell Venue 8 7840 Screen Replacement: step 2, image 1 of 1
      • With a plastic opening tool, pry open the bottom left corner of the screen.
      • The screen is tightly attached to the tablet, so you may have to use a metal spudger to pry it open if the plastic spudger does not do the task.
      Ask FixBot
    3. Dell Venue 8 7840 Screen Replacement: step 3, image 1 of 1
      • Next, pry open the top left corner of the screen.
      Ask FixBot
    4. Dell Venue 8 7840 Screen Replacement: step 4, image 1 of 1
      • Then, pry open the top right corner of the screen.
      Ask FixBot
    5. Dell Venue 8 7840 Screen Replacement: step 5, image 1 of 1
      • Lastly, pry open the bottom right corner of the screen.
      Ask FixBot
    6. Dell Venue 8 7840 Screen Replacement: step 6, image 1 of 1
      • Once you have pried open all the corners of the tablet, carefully open the screen from the right side of the tablet.
      • Do not try and open the screen from the left side of the tablet, because the screen is attached on the left side of the tablet; doing this can damage the tablet.
      Ask FixBot
    7. Dell Venue 8 7840 Screen Replacement: step 7, image 1 of 1
      • Once the tablet is opened, locate the connector.
      Ask FixBot
    8. Dell Venue 8 7840 Screen Replacement: step 8, image 1 of 1
      • Disconnect the connector from the tablet.
      Ask FixBot
Donnelle January
429 Reputation
3 Guides authored
USF Tampa, Team 6-5, Remmell Fall 2016 Member of USF Tampa, Team 6-5, Remmell Fall 2016
USFT-REMMELL-F16S6G5
3 Members
36 Guides authored
3 Guide Comments
i wanted to replace the battery but dont know how to pry the screen open, is it attached with glue? thanks in advance.
dengzc - Reply Share
Where can I find a replacement screen for this device?
Karim Mohamed - Reply Share
Is the OLED connected with EDP 30=pin FPC?
Ron King - Reply Share
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 40
All Time: 1,775
