Dell Venue 7 Rear Facing Camera Replacement
    1. Dell Venue 7 Rear Facing Camera Replacement, Rear Case: step 1, image 1 of 2 Dell Venue 7 Rear Facing Camera Replacement, Rear Case: step 1, image 2 of 2
      • Use a spudger or your fingers to pry off the back case.
      • If your case is badly damaged, use caution because the fragments may be sharp.
      Ask FixBot
    1. Dell Venue 7 Rear Facing Camera Replacement, Battery: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
      Ask FixBot
    2. Dell Venue 7 Rear Facing Camera Replacement: step 3, image 1 of 1
      • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
      • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
      • Do not bend or warp the battery in any way as it can be a fire hazard.
      Ask FixBot
    1. Dell Venue 7 Rear Facing Camera Replacement, Rear Facing Camera: step 4, image 1 of 1
      • Use a spudger to disconnect the camera from the motherboard.
      Ask FixBot
    2. Dell Venue 7 Rear Facing Camera Replacement: step 5, image 1 of 1
      • Remove the camera from the device.
      Ask FixBot
Stephen Rousseau
663 Reputation
4 Guides authored
USF Tampa, Team 11-4, Blackwell Winter 2015 Member of USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 93
All Time: 831
