Dell Venue 7 Motherboard Replacement
    1. Dell Venue 7 Motherboard Replacement, Rear Case: step 1, image 1 of 2 Dell Venue 7 Motherboard Replacement, Rear Case: step 1, image 2 of 2
      • Use a spudger or your fingers to pry off the back case.
      • If your case is badly damaged, use caution because the fragments may be sharp.
      Ask FixBot
    1. Dell Venue 7 Motherboard Replacement, Battery: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Gently disconnect the battery from the motherboard using your fingers or a pair of tweezers.
      Ask FixBot
    2. Dell Venue 7 Motherboard Replacement: step 3, image 1 of 1
      • Remove the battery by pulling it from the edges and carefully peeling it off of the base.
      • There is adhesive keeping the battery in place, so don't be afraid to use a little extra force.
      • Do not bend or warp the battery in any way as it can be a fire hazard.
      Ask FixBot
    1. Dell Venue 7 Motherboard Replacement, Rear Facing Camera: step 4, image 1 of 1
      • Use a spudger to disconnect the camera from the motherboard.
      Ask FixBot
    2. Dell Venue 7 Motherboard Replacement: step 5, image 1 of 1
      • Remove the camera from the device.
      Ask FixBot
    1. Dell Venue 7 Motherboard Replacement, Speaker: step 6, image 1 of 2 Dell Venue 7 Motherboard Replacement, Speaker: step 6, image 2 of 2
      • Use a spudger to remove the ribbon cable that is around the speaker wire.
      Ask FixBot
    2. Dell Venue 7 Motherboard Replacement: step 7, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 7, image 2 of 2
      • Disconnect the speaker wire from the motherboard by prying the connector upwards with the spudger.
      Ask FixBot
    3. Dell Venue 7 Motherboard Replacement: step 8, image 1 of 1
      • Remove the plastic covering on the speaker.
      Ask FixBot
    4. Dell Venue 7 Motherboard Replacement: step 9, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 9, image 2 of 2
      • Gently pull on the wire and remove the speaker.
      Ask FixBot
    1. Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 1 of 3 Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 2 of 3 Dell Venue 7 Motherboard Replacement, Motherboard: step 10, image 3 of 3
      • Disconnect the two remaining connections on the motherboard.
      • To remove the first connector, lift up the clasp and remove the ribbon cable.
      • To remove the second one, use a spudger to gently pry the connector from the motherboard.
      Ask FixBot
    2. Dell Venue 7 Motherboard Replacement: step 11, image 1 of 2 Dell Venue 7 Motherboard Replacement: step 11, image 2 of 2
      • Remove all 8 of the 2.1mm Phillips head screws from the motherboard.
      Ask FixBot
    3. Dell Venue 7 Motherboard Replacement: step 12, image 1 of 1
      • Lift and remove the motherboard from the device.
      Ask FixBot
8 other people completed this guide.
Stephen Rousseau
663 Reputation
4 Guides authored
USF Tampa, Team 11-4, Blackwell Winter 2015 Member of USF Tampa, Team 11-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G4
4 Members
60 Guides authored
2 Guide Comments
unable to open the lock, can the mother board be changed
Amitabh Mishra - Reply Share
Great article.
luisramonjimenez1986 - Reply Share
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 83
All Time: 5,003
