Dell Venue 11 Pro Frame Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
78
All Time:
2,258
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to safely remove the frame from the body of the Dell Venue 11 Pro to access the internal components. It is also a prerequisite to all other replacement guides on this page except for the battery.
Tools
    1. Dell Venue 11 Pro Frame Replacement, Battery: step 1, image 1 of 3 Dell Venue 11 Pro Frame Replacement, Battery: step 1, image 2 of 3 Dell Venue 11 Pro Frame Replacement, Battery: step 1, image 3 of 3
      • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
      Ask FixBot
    2. Dell Venue 11 Pro Frame Replacement: step 2, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 2, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 2, image 3 of 3
      • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
      Ask FixBot
    1. Dell Venue 11 Pro Frame Replacement, Frame: step 3, image 1 of 2 Dell Venue 11 Pro Frame Replacement, Frame: step 3, image 2 of 2
      • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
      • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
      Ask FixBot
    2. Dell Venue 11 Pro Frame Replacement: step 4, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 4, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 4, image 3 of 3
      • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
      Ask FixBot
    3. Dell Venue 11 Pro Frame Replacement: step 5, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 5, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 5, image 3 of 3
      • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
      • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
      Ask FixBot
    4. Dell Venue 11 Pro Frame Replacement: step 6, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 6, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 6, image 3 of 3
      • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
      • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
      Ask FixBot
    5. Dell Venue 11 Pro Frame Replacement: step 7, image 1 of 1
      • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
      Ask FixBot
    6. Dell Venue 11 Pro Frame Replacement: step 8, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 8, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 8, image 3 of 3
      • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
      Ask FixBot
    7. Dell Venue 11 Pro Frame Replacement: step 9, image 1 of 3 Dell Venue 11 Pro Frame Replacement: step 9, image 2 of 3 Dell Venue 11 Pro Frame Replacement: step 9, image 3 of 3
      • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
      Ask FixBot
2 other people completed this guide.
Tom Nguyen
1,295 Reputation
6 Guides authored
USF Tampa, Team S3-G1, Nance Fall 2017 Member of USF Tampa, Team S3-G1, Nance Fall 2017
USFT-NANCE-F17S3G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 78
All Time: 2,258
