Up to 20% off select tools
Dell VRP100 Cover Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
67
All Time:
1,262
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This replacement guide will show you how to replace the cover panel on your Dell VRP100 headset. With the right tools, this replacement is very simple, and is the basis to replacing many more components of your headset.
    1. Dell VRP100 Cover Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 Cover Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 Cover Replacement, Cover Panel: step 1, image 3 of 3
      • Remove the black foam padding by peeling away slowly.
      • Remove the front and back padding from the headset by peeling away slowly.
      Ask FixBot
    2. Dell VRP100 Cover Replacement: step 2, image 1 of 1
      • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Cover panel may need to be pushed in before inserting screws.
      Ask FixBot
    3. Dell VRP100 Cover Replacement: step 3, image 1 of 3 Dell VRP100 Cover Replacement: step 3, image 2 of 3 Dell VRP100 Cover Replacement: step 3, image 3 of 3
      • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
      Ask FixBot
    4. Dell VRP100 Cover Replacement: step 4, image 1 of 3 Dell VRP100 Cover Replacement: step 4, image 2 of 3 Dell VRP100 Cover Replacement: step 4, image 3 of 3
      • Carefully remove the lens and motherboard assembly from the white casing.
      Ask FixBot
Author
with
Marco Salazar
381 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 67
All Time: 1,262
