Up to 20% off select tools
Dell VRP100 Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
61
All Time:
956
Comments: 5
5 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Some reasons you would want to replace the camera in the Dell VRP100 are screen image drifting, image freezing, or tracking/calibration issues. You should be cautious when removing the camera, so the camera lens does not get scratched in the process.
    1. Dell VRP100 Camera Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 Camera Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 Camera Replacement, Cover Panel: step 1, image 3 of 3
      • Remove the black foam padding by peeling away slowly.
      • Remove the front and back padding from the headset by peeling away slowly.
      Ask FixBot
    2. Dell VRP100 Camera Replacement: step 2, image 1 of 1
      • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
      • Cover panel may need to be pushed in before inserting screws.
      Ask FixBot
    3. Dell VRP100 Camera Replacement: step 3, image 1 of 3 Dell VRP100 Camera Replacement: step 3, image 2 of 3 Dell VRP100 Camera Replacement: step 3, image 3 of 3
      • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
      Ask FixBot
    4. Dell VRP100 Camera Replacement: step 4, image 1 of 3 Dell VRP100 Camera Replacement: step 4, image 2 of 3 Dell VRP100 Camera Replacement: step 4, image 3 of 3
      • Carefully remove the lens and motherboard assembly from the white casing.
      Ask FixBot
    1. Dell VRP100 Camera Replacement, Camera: step 5, image 1 of 3 Dell VRP100 Camera Replacement, Camera: step 5, image 2 of 3 Dell VRP100 Camera Replacement, Camera: step 5, image 3 of 3
      • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
      • Separate the lens housing from the motherboard panel.
      Ask FixBot
    2. Dell VRP100 Camera Replacement: step 6, image 1 of 2 Dell VRP100 Camera Replacement: step 6, image 2 of 2
      • Remove the two 2.5mm PH000 screws from the motherboard by rotating counter-clockwise.
      • Remove the four 3.9mm PH000 screws from the white casing by rotating counter-clockwise.
      Ask FixBot
    3. Dell VRP100 Camera Replacement: step 7, image 1 of 2 Dell VRP100 Camera Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the flat-topped connector by lifting it straight up from the motherboard.
      • Carefully remove the camera from the casing with the blunt nose tweezers by holding onto the copper tape.
      • To reinstall, line up the connectors and firmly push until you hear a pop.
      Ask FixBot
Author
with
Lauren Monzon
235 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 61
All Time: 956
