Dell VRP100 Auxiliary Cord Replacement
  1. Dell VRP100 Auxiliary Cord Replacement, Cover Panel: step 1, image 1 of 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: step 1, image 2 of 3 Dell VRP100 Auxiliary Cord Replacement, Cover Panel: step 1, image 3 of 3
    • Remove the black foam padding by peeling away slowly.
    • Remove the front and back padding from the headset by peeling away slowly.
    Ask FixBot
  2. Dell VRP100 Auxiliary Cord Replacement: step 2, image 1 of 1
    • Remove the six 5.5mm PH000 screws from the cover by rotating counter-clockwise.
    • Cover panel may need to be pushed in before inserting screws.
    Ask FixBot
  3. Dell VRP100 Auxiliary Cord Replacement: step 3, image 1 of 3 Dell VRP100 Auxiliary Cord Replacement: step 3, image 2 of 3 Dell VRP100 Auxiliary Cord Replacement: step 3, image 3 of 3
    • Remove the cover using one of the plastic opening tools, and then carefully pull it from the casing.
    Ask FixBot
  4. Dell VRP100 Auxiliary Cord Replacement: step 4, image 1 of 3 Dell VRP100 Auxiliary Cord Replacement: step 4, image 2 of 3 Dell VRP100 Auxiliary Cord Replacement: step 4, image 3 of 3
    • Carefully remove the lens and motherboard assembly from the white casing.
    Ask FixBot
  5. Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: step 5, image 1 of 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: step 5, image 2 of 3 Dell VRP100 Auxiliary Cord Replacement, Auxiliary Cord: step 5, image 3 of 3
    • Separate the external connector of the auxiliary cord.
    • A spudger may be needed to separate the connector.
    Ask FixBot
  6. Dell VRP100 Auxiliary Cord Replacement: step 6, image 1 of 2 Dell VRP100 Auxiliary Cord Replacement: step 6, image 2 of 2
    • Remove the four 2.5mm PH000 screws by rotating counter-clockwise.
    • Separate the lens housing from the motherboard panel.
    Ask FixBot
  7. Dell VRP100 Auxiliary Cord Replacement: step 7, image 1 of 3 Dell VRP100 Auxiliary Cord Replacement: step 7, image 2 of 3 Dell VRP100 Auxiliary Cord Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • In the top right corner of the motherboard panel, peel back the yellow tape covering the bundled auxiliary cable connector using tweezers.
    • Carefully pull out the bundled cable connectors.
    Ask FixBot
Chris Grabow
285 Reputation
2 Guides authored
Cal Poly, Team S17-G1, White Fall 2018 Member of Cal Poly, Team S17-G1, White Fall 2018
CPSU-WHITE-F18S17G1
4 Members
12 Guides authored
1 Guide Comment
Hello, where i can buy the aux cable?
Domenico Rescigno - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 31
All Time: 1,115
