Up to 20% off select tools
Dell VRC100-R Joystick Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
10
Past 30 Days:
71
All Time:
1,196
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Do you have a sticky joystick? Fix it here! Dirt buildup and long-term use cause sticky joysticks. For this guide, you will need a plastic opening tool.
    1. Dell VRC100-R Joystick Replacement, Joystick: step 1, image 1 of 3 Dell VRC100-R Joystick Replacement, Joystick: step 1, image 2 of 3 Dell VRC100-R Joystick Replacement, Joystick: step 1, image 3 of 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Ask FixBot
    2. Dell VRC100-R Joystick Replacement: step 2, image 1 of 2 Dell VRC100-R Joystick Replacement: step 2, image 2 of 2
      • Grab the joystick and pull away from the controller to remove it.
      Ask FixBot
Author
with
Kenneth Liu
169 Reputation
2 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 71
All Time: 1,196
