Up to 20% off select tools
Dell VRC100-R Daughterboard Replacement
Views: 7.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
178
All Time:
7,742
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 22
22 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If you need to reinstall a new joystick unit, access the daughterboard with this guide. Since the daughterboard communicates with the motherboard, you can also replace the daughterboard if your controller does not carry out its functions properly. For this guide, you will need a plastic opening tool and a Phillips #0 screwdriver head. You will not need to do any difficult steps, but open the ZIF connectors carefully.
    1. Dell VRC100-R Daughterboard Replacement, Battery: step 1, image 1 of 3 Dell VRC100-R Daughterboard Replacement, Battery: step 1, image 2 of 3 Dell VRC100-R Daughterboard Replacement, Battery: step 1, image 3 of 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Ask FixBot
    2. Dell VRC100-R Daughterboard Replacement: step 2, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 2, image 2 of 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Ask FixBot
    1. Dell VRC100-R Daughterboard Replacement, Joystick: step 3, image 1 of 3 Dell VRC100-R Daughterboard Replacement, Joystick: step 3, image 2 of 3 Dell VRC100-R Daughterboard Replacement, Joystick: step 3, image 3 of 3
      • Hold the joystick down with your left thumb to make space for the plastic opening tool.
      • Insert the plastic opening tool into the circle above the joystick and pry upwards to lift the front panel.
      • Slide the plastic opening tool around the perimeter until you can lift the front panel.
      • You may hear a popping noise when you pry off the front panel.
      Ask FixBot
    2. Dell VRC100-R Daughterboard Replacement: step 4, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 4, image 2 of 2
      • Grab the joystick and pull away from the controller to remove it.
      Ask FixBot
    1. Dell VRC100-R Daughterboard Replacement, Daughterboard: step 5, image 1 of 2 Dell VRC100-R Daughterboard Replacement, Daughterboard: step 5, image 2 of 2
      • Remove one 6mm Phillips #0 screw.
      Ask FixBot
    2. Dell VRC100-R Daughterboard Replacement: step 6, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 6, image 2 of 2
      • Turn your controller over and orient it so that the thin side is on the top.
      • Remove four 4mm Phillips #0 screws.
      Ask FixBot
    3. Dell VRC100-R Daughterboard Replacement: step 7, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 7, image 2 of 2
      • Turn your controller 90 degrees clockwise and insert a blue plastic opening tool into the crease of the back panel.
      • Push down on the end of the plastic opening tool closest to you to lift the panel up.
      • Slide the plastic opening tool around the perimeter of the back panel until you can remove it.
      • You may hear loud popping noises as the back panel separates from the controller.
      Ask FixBot
    4. Dell VRC100-R Daughterboard Replacement: step 8, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 8, image 2 of 2
      Ask FixBot
    5. Dell VRC100-R Daughterboard Replacement: step 9, image 1 of 3 Dell VRC100-R Daughterboard Replacement: step 9, image 2 of 3 Dell VRC100-R Daughterboard Replacement: step 9, image 3 of 3
      • Use the tip of the blue plastic opening tool or your fingernail to gently flip-up the white locking flap.
      • Make sure to only lift the flap and not the connector socket because the socket easily breaks off.
      • Grab the blue cable and pull away from the socket.
      • To reinstall, insert the blue cable into the connector and close the flap on the black line.
      Ask FixBot
    6. Dell VRC100-R Daughterboard Replacement: step 10, image 1 of 3 Dell VRC100-R Daughterboard Replacement: step 10, image 2 of 3 Dell VRC100-R Daughterboard Replacement: step 10, image 3 of 3
      • Use the tip of a spudger or your fingernail to gently flip-up the small white flap holding the orange ribbon cable.
      • Grab the orange cable and pull away from the socket.
      • To reinstall, insert the orange cable into the connector and close the flap on the white line.
      Ask FixBot
    7. Dell VRC100-R Daughterboard Replacement: step 11, image 1 of 2 Dell VRC100-R Daughterboard Replacement: step 11, image 2 of 2
      • Place two fingers on the perimeter of the daughterboard and lift it away from the controller.
      Ask FixBot
22 other people completed this guide.
Author
with
Steven Pineda
1,049 Reputation
3 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
1 Guide Comment
Really instructive & easy to follow!
Daisy Chavez - Reply Share
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 178
All Time: 7,742
