Up to 20% off select tools
Dell Studio 1558 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
57
All Time:
605
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
RAM is crucial for a computer to function properly. Faulty RAM can cause a variety of issues in a computer, from onscreen graphical errors to random crashes that seemingly occur out of nowhere.
The RAM modules are easy to access on the Dell Studio 1558. It is important to properly disengage the holding arms in order to avoid damaging the components.
    1. Dell Studio 1558 RAM Replacement, Battery: step 1, image 1 of 2 Dell Studio 1558 RAM Replacement, Battery: step 1, image 2 of 2
      • To begin, flip over the laptop.
      Ask FixBot
    2. Dell Studio 1558 RAM Replacement: step 2, image 1 of 1
      • Next, slide the slider to the right and hold it in place.
      Ask FixBot
    3. Dell Studio 1558 RAM Replacement: step 3, image 1 of 2 Dell Studio 1558 RAM Replacement: step 3, image 2 of 2
      • While holding down the slider, gently remove the battery.
      Ask FixBot
    4. Dell Studio 1558 RAM Replacement: step 4, image 1 of 1
      • The battery has been successfully removed.
      Ask FixBot
    1. Dell Studio 1558 RAM Replacement, RAM: step 5, image 1 of 3 Dell Studio 1558 RAM Replacement, RAM: step 5, image 2 of 3 Dell Studio 1558 RAM Replacement, RAM: step 5, image 3 of 3
      • Make sure the battery is properly removed. If not, you could experience shocks.
      • Unscrew the three screws (Phillips #0) on the back panel to reveal the innards underneath the panel. It is helpful to keep these screws in the holes of the back panel.
      • Pry the back panel off and set aside.
      • A little bit of force may be necessary in removing the panel as there are some minor plastic clips holding the panel in place in addition to the screws.
      Ask FixBot
    2. Dell Studio 1558 RAM Replacement: step 6, image 1 of 2 Dell Studio 1558 RAM Replacement: step 6, image 2 of 2
      • Two small tabs are located on either side of the RAM stick. Push those tabs inwards to release the RAM stick.
      • A new RAM stick can be inserted by inserting the golden pins into the slot, and then lowering the rest of the RAM stick into the slot.
      Ask FixBot
Author
with
Nic Birky
154 Reputation
2 Guides authored
IUPUI, Team 4-4, Beck Spring 2022 Member of IUPUI, Team 4-4, Beck Spring 2022
IUPUI-BECK-S22S4G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 57
All Time: 605
