Up to 20% off select tools
Dell Studio 1558 Keyboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
65
All Time:
771
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Keyboard is one of the most used parts on a computer. One of the most common keyboard issues is a key falling off, but more serious problems can occur which might require replacing the whole module.
Often times the whole case of the laptop will have to be disassembled in order to remove and replace the keyboard. Extra caution must be taken in order to prevent damaging the fragile ribbon cables of the keyboard.
    1. Dell Studio 1558 Keyboard Replacement, Battery: step 1, image 1 of 2 Dell Studio 1558 Keyboard Replacement, Battery: step 1, image 2 of 2
      • To begin, flip over the laptop.
      Ask FixBot
    2. Dell Studio 1558 Keyboard Replacement: step 2, image 1 of 1
      • Next, slide the slider to the right and hold it in place.
      Ask FixBot
    3. Dell Studio 1558 Keyboard Replacement: step 3, image 1 of 2 Dell Studio 1558 Keyboard Replacement: step 3, image 2 of 2
      • While holding down the slider, gently remove the battery.
      Ask FixBot
    4. Dell Studio 1558 Keyboard Replacement: step 4, image 1 of 1
      • The battery has been successfully removed.
      Ask FixBot
    1. Dell Studio 1558 Keyboard Replacement, Keyboard: step 5, image 1 of 3 Dell Studio 1558 Keyboard Replacement, Keyboard: step 5, image 2 of 3 Dell Studio 1558 Keyboard Replacement, Keyboard: step 5, image 3 of 3
      • Make sure the battery is properly removed. If not, you could experience shocks.
      • Unscrew the three screws (Phillips #0) on the back panel to reveal the innards underneath the panel. It is helpful to keep these screws in the holes of the back panel.
      • Pry the back panel off and set aside.
      • A little bit of force may be necessary in removing the panel as there are some minor plastic clips holding the panel in place in addition to the screws.
      Ask FixBot
    2. Dell Studio 1558 Keyboard Replacement: step 6, image 1 of 2 Dell Studio 1558 Keyboard Replacement: step 6, image 2 of 2
      • Remove the visible screws with a Phillips #0 screwdriver.
      • Note that there are a couple different types of screws, so you might want to organize them, unless you love confusion.
      • There are six regular screws.
      • There is one screw marked M 2X3 .
      Ask FixBot
    3. Dell Studio 1558 Keyboard Replacement: step 7, image 1 of 2 Dell Studio 1558 Keyboard Replacement: step 7, image 2 of 2
      • Remove the screws from the laptop's base.
      • There are seven regular screws.
      • There is one M2X3 screw that is where the battery was located.
      Ask FixBot
    4. Dell Studio 1558 Keyboard Replacement: step 8, image 1 of 3 Dell Studio 1558 Keyboard Replacement: step 8, image 2 of 3 Dell Studio 1558 Keyboard Replacement: step 8, image 3 of 3
      • Now flip the laptop over and open it up.
      • Insert a pry tool under the black plastic guard around the edge of the keyboard and pry the guard up. Plastic snaps are holding the guard in place.
      • You can also do this with your hands once you have enough pried up, but keep in mind that the plastic is thin and capable of breaking if bent too far.
      • Place the keyboard guard in a safe location out of harm's way.
      Ask FixBot
    5. Dell Studio 1558 Keyboard Replacement: step 9, image 1 of 3 Dell Studio 1558 Keyboard Replacement: step 9, image 2 of 3 Dell Studio 1558 Keyboard Replacement: step 9, image 3 of 3
      • Use the Phillips screwdriver to remove the two screws that attach the keyboard to the casing.
      • Once the screws are out, gently tip the keyboard up to view the ribbon cable beneath.
      • A ribbon cable connects the keyboard to the motherboard. Be gentle removing the keyboard as to not damage the ribbon cable beneath.
      • Carefully unlatch and remove the ribbon cable from the motherboard by lifting up the black tab (with a spudger or finger) and slipping the cable out.
      • Put the keyboard off to the side. Make sure it is in a secure location.
      Ask FixBot
    6. Dell Studio 1558 Keyboard Replacement: step 10, image 1 of 3 Dell Studio 1558 Keyboard Replacement: step 10, image 2 of 3 Dell Studio 1558 Keyboard Replacement: step 10, image 3 of 3
      • If a key has fallen off, align it over the spot where it was located.
      • Once aligned, the key can be pressed back into place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take care when placing the parts back in to avoid damaging any of the components.
Author
with
Nic Birky
154 Reputation
2 Guides authored
IUPUI, Team 4-4, Beck Spring 2022 Member of IUPUI, Team 4-4, Beck Spring 2022
IUPUI-BECK-S22S4G4
4 Members
48 Guides authored
1 Guide Comment
make sure to also have the keyboard for the replacement too and all tools needed to fix it
Tucker Kindle - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 771
