Up to 20% off select tools
Dell Studio 1555 Keyboard Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
83
All Time:
1,574
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
You may need to replace your keyboard due to failure. You will need a Phillips 1 screwdriver for this guide.
    1. Dell Studio 1555 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Turn off and unplug the laptop.
      • Failure to properly turn off device before handling the battery could result in electrical shock.
      • Flip the laptop so the underside is facing up with the battery closest to you.
      Ask FixBot
    2. Dell Studio 1555 Keyboard Replacement: step 2, image 1 of 3 Dell Studio 1555 Keyboard Replacement: step 2, image 2 of 3 Dell Studio 1555 Keyboard Replacement: step 2, image 3 of 3
      • Slide the locking switch to the left to release the battery.
      Ask FixBot
    3. Dell Studio 1555 Keyboard Replacement: step 3, image 1 of 1
      • Gently pull the battery away from the device.
      Ask FixBot
    1. Dell Studio 1555 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
      Ask FixBot
    2. Dell Studio 1555 Keyboard Replacement: step 5, image 1 of 2 Dell Studio 1555 Keyboard Replacement: step 5, image 2 of 2
      • Flip the laptop over and flatten it out as much as possible.
      • Unsnap the media control cover from the laptop starting nearest to the display.
      Ask FixBot
    3. Dell Studio 1555 Keyboard Replacement: step 6, image 1 of 2 Dell Studio 1555 Keyboard Replacement: step 6, image 2 of 2
      • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
      Ask FixBot
    4. Dell Studio 1555 Keyboard Replacement: step 7, image 1 of 1
      • Slowly lift the keyboard away from the base.
      • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
      Ask FixBot
    5. Dell Studio 1555 Keyboard Replacement: step 8, image 1 of 3 Dell Studio 1555 Keyboard Replacement: step 8, image 2 of 3 Dell Studio 1555 Keyboard Replacement: step 8, image 3 of 3
      • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
      Ask FixBot
    6. Dell Studio 1555 Keyboard Replacement: step 9, image 1 of 1
      • Remove the keyboard
      Ask FixBot
2 other people completed this guide.
Author
with
Hunter Tuck
214 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 83
All Time: 1,574
