Up to 20% off select tools
Dell Studio 1555 Display Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
94
All Time:
2,252
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your screen becomes unresponsive you may need to replace it. A Philips 1 screwdriver and a plastic opening tool are required for this guide.
    1. Dell Studio 1555 Display Replacement, Battery: step 1, image 1 of 1
      • Turn off and unplug the laptop.
      • Failure to properly turn off device before handling the battery could result in electrical shock.
      • Flip the laptop so the underside is facing up with the battery closest to you.
      Ask FixBot
    2. Dell Studio 1555 Display Replacement: step 2, image 1 of 3 Dell Studio 1555 Display Replacement: step 2, image 2 of 3 Dell Studio 1555 Display Replacement: step 2, image 3 of 3
      • Slide the locking switch to the left to release the battery.
      Ask FixBot
    3. Dell Studio 1555 Display Replacement: step 3, image 1 of 1
      • Gently pull the battery away from the device.
      Ask FixBot
    1. Dell Studio 1555 Display Replacement, Display: step 4, image 1 of 2 Dell Studio 1555 Display Replacement, Display: step 4, image 2 of 2
      • Insert a plastic opening tool between the bezel and the display cover.
      • Wiggle it to the release the latches.
      • Separate the bezel from the cover.
      Ask FixBot
    2. Dell Studio 1555 Display Replacement: step 5, image 1 of 2 Dell Studio 1555 Display Replacement: step 5, image 2 of 2
      • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
      Ask FixBot
    3. Dell Studio 1555 Display Replacement: step 6, image 1 of 1
      • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
      • Unplug the camera cable.
      Ask FixBot
    4. Dell Studio 1555 Display Replacement: step 7, image 1 of 2 Dell Studio 1555 Display Replacement: step 7, image 2 of 2
      • Place the LCD face down on the top cover.
      • Remove the sticky tape securing the video cable connector.
      • Unplug the video cable from the screen.
      Ask FixBot
    5. Dell Studio 1555 Display Replacement: step 8, image 1 of 3 Dell Studio 1555 Display Replacement: step 8, image 2 of 3 Dell Studio 1555 Display Replacement: step 8, image 3 of 3
      • Remove the LCD from the laptop.
      • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
      • You will have to transfer the mounting brackets to the new screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Josh Boone
586 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 94
All Time: 2,252
