Dell Studio 1535 Hard Drive Replacement
    1. Dell Studio 1535 Hard Drive Replacement, Hard Drive: step 1, image 1 of 3 Dell Studio 1535 Hard Drive Replacement, Hard Drive: step 1, image 2 of 3 Dell Studio 1535 Hard Drive Replacement, Hard Drive: step 1, image 3 of 3
      • Gather tools and materials
      • Flip over laptop, and remove battery as a safety precaution
      Ask FixBot
    2. Dell Studio 1535 Hard Drive Replacement: step 2, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 2, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 2, image 3 of 3
      • If you look at the bottom of the laptop, you will notice that there is a panel that is removable
      • Unscrew the screws that hold the panel in place
      • Unscrew the screws until they are loose. They will not come out of the panel
      • After loosening all the screws, lift the panel up from the main chassis
      • You may need to use a flathead screwdriver to lift the panel
      Ask FixBot
    3. Dell Studio 1535 Hard Drive Replacement: step 3, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 3, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Now we have access to the internals of the laptop, pretty neat
      • If the battery is away from you, the hard drive should be closer towards you on the left
      • Start by removing the screws holding the caddy into the chassis
      • These screws have a more rounded top, and are longer
      • Once loosened, you can remove with your fingers or tweezers, and then set them aside
      Ask FixBot
    4. Dell Studio 1535 Hard Drive Replacement: step 4, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 4, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 4, image 3 of 3
      • Now we remove the screws holding the drive to the caddy
      • These screws are have a flatter head, and are shorter
      • These are standard drive screws that are used to mount any hard drive to a mounting device, such as brackets to put it in a desktop computer
      • The manufacturer likes to put these in very tightly, and it may take some effort to remove. I suggest using a screwdriver with a bigger handle, not the one I am using
      • Set these screws aside, apart from the screws we removed in the last step
      Ask FixBot
    5. Dell Studio 1535 Hard Drive Replacement: step 5, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 5, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 5, image 3 of 3
      • Now that the screws are removed, the caddy can be removed from the chassis and drive
      • Pull the black tab on the right side of the caddy, and pull up
      • It might take some wiggling but it should come out
      Ask FixBot
    6. Dell Studio 1535 Hard Drive Replacement: step 6, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 6, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 6, image 3 of 3
      • Now that the caddy is removed, we can lift the drive out of it's place
      • It should lift out easily, but it will still be attached with a cable
      • Set it aside on top of the optical drive (the metal surface)
      Ask FixBot
    7. Dell Studio 1535 Hard Drive Replacement: step 7, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 7, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 7, image 3 of 3
      • Now that the drive is removed, we have to remove the cable connecting it to the motherboard
      • It may be hard to do at first, but there are some groves that you can use to hold on to
      • Pull the connector from the drive gently
      • Wiggling the connector a bit does help a little
      Ask FixBot
    8. Dell Studio 1535 Hard Drive Replacement: step 8, image 1 of 3 Dell Studio 1535 Hard Drive Replacement: step 8, image 2 of 3 Dell Studio 1535 Hard Drive Replacement: step 8, image 3 of 3
      • If you found it difficult to remove the drive or the cable connecting the drive to the motherboard, you can remove the whole cable at once
      • If you look to the right of the drive, you will see another tab, this one is black, but I've also seen blue ones
      • Pull this tab gently in order to remove the cable
      • Again, wiggling also helps
      Ask FixBot
    9. Dell Studio 1535 Hard Drive Replacement: step 9, image 1 of 2 Dell Studio 1535 Hard Drive Replacement: step 9, image 2 of 2
      • If you removed the drive using steps 1-7 then what you have should be left in picture 1
      • If you had trouble removing the drive, and you went through to step 8, then the parts remaining will be in picture 2
      • The drive should have a SATA interface, so you should be able to mount it into another computer using 2.5" to 3.5" converter brackets and a SATA cable
      Ask FixBot
13 other people completed this guide.
Eric Bentley
1,350 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 115
All Time: 21,229
