Dell Studio 1440 Hard Drive Replacement
    1. Dell Studio 1440 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latch until it clicks into place.
      • Slide the battery out of the battery bay.
      Ask FixBot
    1. Dell Studio 1440 Hard Drive Replacement, KeyBoard: step 2, image 1 of 1
      • Turn the computer over and open the display.
      • Ease the keyboard surround up using your fingers or a plastic scribe.
      Ask FixBot
    2. Dell Studio 1440 Hard Drive Replacement: step 3, image 1 of 1
      • Lift the keyboard surround off the computer.
      • Remove the two screws at the top of the keyboard.
      • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
      • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
      • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
      Ask FixBot
    3. Dell Studio 1440 Hard Drive Replacement: step 4, image 1 of 1
      • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
      • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
      • Lift the keyboard off the computer.
      Ask FixBot
    1. Dell Studio 1440 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Remove the four screws securing the hard drive assembly to the computer base.
      • Pull the black pull-tab to lift the hard drive assembly out of the computer base and disconnect the interposer from the SATA connector on the system board.
      Ask FixBot
    2. Dell Studio 1440 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the four screws securing the hard drive cage to the hard drive.
      • Pull the interposer to disconnect it from the hard drive.
      • Lift the hard drive off the hard drive cage.
      Ask FixBot
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 65
All Time: 721
