Up to 20% off select tools
Dell Streak 7 Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
23
Past 30 Days:
148
All Time:
1,056
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the screen on your Dell Streak 7. This guide will show you how to remove the old display.
    1. Dell Streak 7 Screen  Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Insert the spudger under the capacitive button panel, and slide the spudger all the way around.
      • You will want to heat up the screen edges with the iOpener to help facilitate removal.
      Ask FixBot
    2. Dell Streak 7 Screen  Replacement: step 2, image 1 of 1
      • Remove the button cover by lifting the cover away from the tablet.
      Ask FixBot
    3. Dell Streak 7 Screen  Replacement: step 3, image 1 of 1
      • Using the Torx screwdriver, remove the 4mm screws.
      Ask FixBot
    4. Dell Streak 7 Screen  Replacement: step 4, image 1 of 1
      • With the Torx screwdriver, remove the two 5mm screws.
      Ask FixBot
    5. Dell Streak 7 Screen  Replacement: step 5, image 1 of 2 Dell Streak 7 Screen  Replacement: step 5, image 2 of 2
      • Using the spudger, insert it under the black side panel. Slide the spudger all the way around until the cover piece comes off.
      • With the Torx screwdriver, remove the two 4mm screws.
      Ask FixBot
    6. Dell Streak 7 Screen  Replacement: step 6, image 1 of 1
      • Use the spudger to go along the edges of the device and pop out the latches securing the display to the case.
      Ask FixBot
    7. Dell Streak 7 Screen  Replacement: step 7, image 1 of 2 Dell Streak 7 Screen  Replacement: step 7, image 2 of 2
      • Ribbon cables are very sensitive and prone to breaking
      • Disconnect the ribbon cables by unlocking the connector and pulling the cable out slowly.
      • Make sure all the cables are unplugged before opening the device completely. Failure to do so might lead to broken or torn cables.
      Ask FixBot
    1. Dell Streak 7 Screen  Replacement, Screen: step 8, image 1 of 1
      • Using the screwdriver, remove the 3mm Torx T5 screws around the metal housing.
      Ask FixBot
    2. Dell Streak 7 Screen  Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, peel off the tape securing the screen to the metal cage around it.
      Ask FixBot
    3. Dell Streak 7 Screen  Replacement: step 10, image 1 of 2 Dell Streak 7 Screen  Replacement: step 10, image 2 of 2
      • Pull out the ribbon cables through the opening in the metal cage.
      • Lift up the metal cage surrounding the screen by swinging the cage from one side.
      Ask FixBot
    4. Dell Streak 7 Screen  Replacement: step 11, image 1 of 1
      • Remove the screen by lifting the screen from the front glass.
      Ask FixBot
2 other people completed this guide.
Author
with
Ali Benjelloun
385 Reputation
3 Guides authored
USF Tampa, Team 4-6, Passmore Fall 2016 Member of USF Tampa, Team 4-6, Passmore Fall 2016
USFT-PASSMORE-F16S4G6
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 148
All Time: 1,056
