Up to 20% off select tools
Dell Precision T5600 RAM Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
14
Past 30 Days:
67
All Time:
1,397
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
RAM stands for Random-Access-Memory. RAM is essentially a short-term memory that is used to store data for computer processors to receive instructions. Adding more RAM is the easiest way to boost the performance of your computer. Make sure to check the available RAM slots in your motherboard. Also, check the specification of the motherboard to find out the maximum RAM capacity that is supported by your motherboard.
Only ECC RAM is compatible with the DELL Precision T5600 workstation.
Before you begin, check your workstation's requirements to ensure that your replacement RAM is compatible with your workstation.
    1. Dell Precision T5600 RAM Replacement, RAM: step 1, image 1 of 1
      • Unplug the computer from the power supply before any maintenance or disassembly.
      • Lay the case on its side with the handle side pointing up. Remove the side panel of the computer case by pulling on the handle, as shown in this step.
      • Be sure to use an anti-static mat to ensure important components are not damaged by static electricity.
      Ask FixBot
    2. Dell Precision T5600 RAM Replacement: step 2, image 1 of 1
      • Unlock the RAM by pressing down on the tabs on each end of the RAM socket.
      • Once both tabs have been pushed down, gently pull out the existing RAM stick from the motherboard.
      Ask FixBot
    3. Dell Precision T5600 RAM Replacement: step 3, image 1 of 2 Dell Precision T5600 RAM Replacement: step 3, image 2 of 2
      • Line up the RAM with the groove on the connector line.
      • Do not touch the gold connectors.
      Ask FixBot
    4. Dell Precision T5600 RAM Replacement: step 4, image 1 of 2 Dell Precision T5600 RAM Replacement: step 4, image 2 of 2
      • Gently insert the RAM into the socket until you feel the tabs from Step 3 click into place.
      • Ensure that both ends of the RAM are secured by their tabs.
      Ask FixBot
    5. Dell Precision T5600 RAM Replacement: step 5, image 1 of 1
      • Reattach the side panel from Step 2. Plug your computer back up to the power supply and power on your computer.
      • Once powered on, to verify the installation:
      • Right-click on 'This PC'
      • Left-click on 'Properties'
      Ask FixBot
Author
with
Fahad Khan
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 67
All Time: 1,397
