Dell Precision T3400 Power Supply Replacement
  1. Dell Precision T3400 Power Supply Replacement, Disconnect the DC power cables from the system board and the drives.: step 1, image 1 of 1
    • Pay special attention to where the DC power cables are plugged in so that they can be replaced the same way.
    • You may need to remove the heat-sink assembly in order to detach certain cables.
    Ask FixBot
  2. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: step 2, image 1 of 1
    • Remove the four screws on the back of the power supply using a standard Phillips-head screwdriver.
    Ask FixBot
  3. Dell Precision T3400 Power Supply Replacement, Remove the power supply from the computer case.: step 3, image 1 of 1
    • Press the secure tab down and slide the power supply out of its bracket to remove it.
    Ask FixBot
  4. Dell Precision T3400 Power Supply Replacement, Install the new power supply.: step 4, image 1 of 1
    • Slide the power supply into the empty bracket. It will click into place.
    • Replace the four screws to secure the power supply to the computer case.
    Ask FixBot
  5. Dell Precision T3400 Power Supply Replacement, Reconnect the DC power cables.: step 5, image 1 of 1
    • Remember to use the case's secure tabs to hold cables out of the way.
    • If you removed the heat-sink assembly in order to remove any power supply cables, be sure to re-install the assembly.
    Ask FixBot
9 other people completed this guide.
Josette Cormier
13 Reputation
2 Guides authored
UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 1-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G2
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 37
All Time: 8,989
