Up to 20% off select tools
Dell Precision M6800 Keyboard Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
95
All Time:
2,547
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Precision M6800 Keyboard Replacement, Dell Precision M6800: step 1, image 1 of 1
      • Replacing Dell Precision M6800's keyboard
      Ask FixBot
    2. Dell Precision M6800 Keyboard Replacement: step 2, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 2, image 2 of 2
      • Before any repair, you should remove battery
      Ask FixBot
    3. Dell Precision M6800 Keyboard Replacement: step 3, image 1 of 1
      • Pry and remove the frame around keyboard (it's a bit lighter than rest of casing).
      Ask FixBot
    4. Dell Precision M6800 Keyboard Replacement: step 4, image 1 of 1
      • Unscrew 4 fastening screws which are at bottom of keyboard
      Ask FixBot
    5. Dell Precision M6800 Keyboard Replacement: step 5, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 5, image 2 of 2
      • Pry out four hooks which are on the sides of keyboard (two per one site)
      • Be carefull to not break of hooks - use constant force and do it slowly
      Ask FixBot
    6. Dell Precision M6800 Keyboard Replacement: step 6, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 6, image 2 of 2
      • Pick up a little keyboard and eject it. Than pick up harder but DO NOT take it out
      • DO NOT take keyboard out, it is connect to the motherboard and you must unhook it in next step
      Ask FixBot
    7. Dell Precision M6800 Keyboard Replacement: step 7, image 1 of 2 Dell Precision M6800 Keyboard Replacement: step 7, image 2 of 2
      • Pry up the white part of connector (constant for both sides) and eject connecting flex
      Ask FixBot
5 other people completed this guide.
Author
with
Szymon Milewski
831 Reputation
3 Guides authored
2 Guide Comments
Great job, thank you
kali1902 - Reply Share
Broke off the stupid white clip holding the connector in place go to h ell
Stan B - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 95
All Time: 2,547
