Dell Precision M6700 Hard Drive Replacement
    1. Dell Precision M6700 Hard Drive Replacement, Battery: step 1, image 1 of 2 Dell Precision M6700 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Slide the release latch to unlock the battery.
      • Flip and remove the battery from the computer.
      Ask FixBot
    1. Dell Precision M6700 Hard Drive Replacement, Base Cover: step 2, image 1 of 2 Dell Precision M6700 Hard Drive Replacement, Base Cover: step 2, image 2 of 2
      • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
      • Flip and remove the base cover from the computer
      Ask FixBot
    1. Dell Precision M6700 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Remove the screws that secure the primary hard drive to the computer. Slide the primary hard -drive latch to the unlock position and pull out the hard drive from the computer.
      Ask FixBot
    2. Dell Precision M6700 Hard Drive Replacement: step 4, image 1 of 1
      • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
      • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
      Ask FixBot
    3. Dell Precision M6700 Hard Drive Replacement: step 5, image 1 of 1
      • Remove the screw that secure that secondary hard drive in place.
      • Pull the tab upward and remove the secondary hard drive from the computer.
      Ask FixBot
    4. Dell Precision M6700 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the screw that secure secondary hard drive to the bracket.
      • Remove the secondary hard drive from the bracket.
      Ask FixBot
4 other people completed this guide.
Johnathan Hammond
46,320 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 81
All Time: 5,920
