Dell Precision M6600 LCD Replacement
    1. Dell Precision M6600 LCD Replacement, LCD: step 1, image 1 of 1
      • Open the laptop lid fully and place it on a stable surface to access the screen.
      • Make sure the laptop is unplugged and the battery is removed to prevent electrical hazards.
      Ask FixBot
    2. Dell Precision M6600 LCD Replacement: step 2, image 1 of 2 Dell Precision M6600 LCD Replacement: step 2, image 2 of 2
      • Use the iFixit opening tool to carefully pry around the edges of the screen bezel, starting from a corner or along the bottom edge. Gently work around the perimeter to release each of the clips.
      • Once it has been loosened, lift the bezel away from the display and set it aside in a safe place to prevent any damage.
      Ask FixBot
    3. Dell Precision M6600 LCD Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the screws securing the LCD screen to the display frame.
      • Once all screws are removed, set them aside in a safe place.
      Ask FixBot
    4. Dell Precision M6600 LCD Replacement: step 4, image 1 of 1
      • Carefully disconnect the gold LCD cable from the back of the screen by gently pulling on only the connector, not the cable itself.
      • LCD connectors are fragile. apply gentle, even pressure when disconnecting to avoid bending or breaking the pins.
      • Once the cable is fully detached, lift the LCD screen out of the display assembly and place it on a clean, flat surface to prevent scratches or damage.
      Ask FixBot
Kaley lindsay
600 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 64
All Time: 1,449
