Dell Precision M6600 Hard Drive Replacement
    1. Dell Precision M6600 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
      Ask FixBot
    1. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: step 2, image 1 of 2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: step 2, image 2 of 2
      • Using Phillips screwdriver, remove 2 screws holding case.
      • Slide case towards back of laptop then lift off to remove.
      Ask FixBot
    2. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: step 3, image 1 of 2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: step 3, image 2 of 2
      • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
      • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
      Ask FixBot
    3. Dell Precision M6600 Hard Drive Replacement: step 4, image 1 of 1
      • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
      Ask FixBot
4 other people completed this guide.
Kaley lindsay
600 Reputation
4 Guides authored
1 Guide Comment
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 90
All Time: 4,938
