Up to 20% off select tools
Dell Precision M6400 Memory Module Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
59
All Time:
1,988
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Precision M6400 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latch and remove the battery.
      Ask FixBot
    1. Dell Precision M6400 Memory Module Replacement, Base Cover: step 2, image 1 of 1
      • Remove the two M2 x 3-mm screws.
      • Slide the cover toward the front of the computer to release the tabs from the base assembly.
      • Remove the cover from the base assembly.
      Ask FixBot
    1. Dell Precision M6400 Memory Module Replacement, LED Cover: step 3, image 1 of 1
      • Starting on the left, gently lift the LED cover and disconnect the power cable and the biometer cable if present.
      Ask FixBot
    1. Dell Precision M6400 Memory Module Replacement, KeyBoard: step 4, image 1 of 1
      • Remove the four M2 x 3-mm screws along the top of the keyboard.
      • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time- consuming to replace. Exercise care when removing and handling the keyboard.
      • Use the metal pull tabs to gently slide the keyboard toward the back of the computer to disconnect the keyboard.
      Ask FixBot
    1. Dell Precision M6400 Memory Module Replacement, Memory Module: step 5, image 1 of 1
      • NOTICE: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
      • Remove the memory module from the connector.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 59
All Time: 1,988
