Dell Precision M6400 Hard Drive Replacement
    1. Dell Precision M6400 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latch and remove the battery.
      Ask FixBot
    1. Dell Precision M6400 Hard Drive Replacement, Base Cover: step 2, image 1 of 1
      • Remove the two M2 x 3-mm screws.
      • Slide the cover toward the front of the computer to release the tabs from the base assembly.
      • Remove the cover from the base assembly.
      Ask FixBot
    1. Dell Precision M6400 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
      • Push in, then pull up on the safety loop to remove the cover.
      • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
      Ask FixBot
    2. Dell Precision M6400 Hard Drive Replacement: step 4, image 1 of 1
      • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
      • Set the pull tab aside to use with the replacement HDD1.
      Ask FixBot
    3. Dell Precision M6400 Hard Drive Replacement: step 5, image 1 of 1
      • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
      • Pull up on the pull tab to remove the carrier.
      Ask FixBot
    4. Dell Precision M6400 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
      • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
      • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
      Ask FixBot
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 76
All Time: 5,050
