Dell Precision M4800 Four Slot RAM Replacement
    1. Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: step 1, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: step 1, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement, DDR3 Ram Card: step 1, image 3 of 3
      • Ensure that all electrical sources are removed and turned off.
      • Unplug the charger from the computer.
      • Flip the computer, so the bottom is facing upwards.
      • Slide the release latch to release the battery.
      • Lift and remove the battery from the computer.
      Ask FixBot
    2. Dell Precision M4800 Four Slot RAM Replacement: step 2, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 2, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 2, image 3 of 3
      • Using a Phillips #1 screwdriver, remove the two 5 mm screws fastening the backplate.
      • Slide the base cover towards the rear of the computer.
      • Lift the base cover and remove it from the computer,
      Ask FixBot
    3. Dell Precision M4800 Four Slot RAM Replacement: step 3, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 3, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 3, image 3 of 3
      • Pull the retention clips away from the RAM card simultaneously.
      • Lift the RAM card upwards.
      • Pull the first RAM card away from the slot.
      • Repeat this step to remove the second RAM card.
      Ask FixBot
    4. Dell Precision M4800 Four Slot RAM Replacement: step 4, image 1 of 2 Dell Precision M4800 Four Slot RAM Replacement: step 4, image 2 of 2
      • Insert the replacement RAM card back into the slot diagonally.
      • The RAM card is keyed and will only go into the slot in one orientation.
      • Lightly press the RAM card into the computer.
      • Ensure the RAM card is seated properly. Both tabs should be secured to the RAM card's grooves.
      Ask FixBot
    5. Dell Precision M4800 Four Slot RAM Replacement: step 5, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 5, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 5, image 3 of 3
      • Using a guitar pick or an iFixit Opening Pick, pry a section of the keyboard trim.
      • Gently lift the trim with your finger until multiple tabs of the keyboard trim are unclipped. Go around the trim and unclip all tabs one by one.
      • While lifting the trim you will hear multiple snaps. This is normal as multiple tabs may unclip at once.
      • Once all the tabs are unclipped, remove the keyboard trim from the device.
      Ask FixBot
    6. Dell Precision M4800 Four Slot RAM Replacement: step 6, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 6, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 6, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the three 3 mm screws.
      • Ensure that all the screws are completely removed from the keyboard. They will easily get lost in the computer if they fall out.
      • Lift the keyboard gently from retaining clips.
      • Do not immediately remove the keyboard from the computer. You could damage a connector if you lift it up too quickly or rip it away.
      Ask FixBot
    7. Dell Precision M4800 Four Slot RAM Replacement: step 7, image 1 of 2 Dell Precision M4800 Four Slot RAM Replacement: step 7, image 2 of 2
      • Disconnect the ribbon connector that attaches the keyboard to the motherboard.
      • Remove the keyboard.
      Ask FixBot
    8. Dell Precision M4800 Four Slot RAM Replacement: step 8, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 8, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 8, image 3 of 3
      • Pull the retention clips away from the first RAM card simultaneously.
      • Lift the first RAM card upwards.
      Ask FixBot
    9. Dell Precision M4800 Four Slot RAM Replacement: step 9, image 1 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 9, image 2 of 3 Dell Precision M4800 Four Slot RAM Replacement: step 9, image 3 of 3
      • Pull the retention clips away from the second RAM card simultaneously.
      • Lift the second RAM card upwards.
      • Pull the second RAM card away from the slot.
      Ask FixBot
    10. Dell Precision M4800 Four Slot RAM Replacement: step 10, image 1 of 2 Dell Precision M4800 Four Slot RAM Replacement: step 10, image 2 of 2
      • Insert the first replacement RAM card into the slot at an angle.
      Ask FixBot
    11. Dell Precision M4800 Four Slot RAM Replacement: step 11, image 1 of 2 Dell Precision M4800 Four Slot RAM Replacement: step 11, image 2 of 2
      • Insert the second replacement RAM card into the slot at an angle.
      • The RAM card is keyed and will only go into the slot at one orientation.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
Posting in case this helps anyone else. I was donated 2 Dell Precision M4800 laptops with i7 processors. Both had newest BIOS I could find, A26 Dec 2019.
I put 4x4 GB RAM for a total of 16 GB in the laptop with i7 4710M and all was recognized.
When I put 4x4 GB RAM for a total of 16 GB in the laptop with i7 4610M, only slots AB (bottom of laptop) were recognized, for a total of 8 GB. If I removed the RAM sticks from slots AB, then slots CD (under keyboard) were recognized for a total of 8 GB. I could not get all 4 slots (ABCD) to be recognized.
I think the problem is the CPU i7 4610 is dual core, and only recognizes a maximum of 2 slots of RAM. The CPU i7 4710M is quad core and can recognize all 4 slots of RAM.
I tested with 2x 8GB sticks in i7 4610M and it recognized 16 GB RAM.
Jessica - Reply Share
Past 24 Hours: 5
Past 7 Days: 39
Past 30 Days: 135
All Time: 5,631
