Up to 20% off select tools
Dell Precision M4700 Optical Drive Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
16
Past 30 Days:
53
All Time:
986
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a faulty optical drive in your Dell Precision M4700.
The optical drive is a piece of hardware that uses laser technology to allow your computer to read, edit, and/or delete information from discs such as DVDs and CDs. A failing optical drive will remove the ability from your computer to read the discs.
Before using this guide, be sure to review the Dell Precision M4700 Troubleshooting Often times, checking for debris in the drive will fix the issue.
    1. Dell Precision M4700  Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Slide the release latch to unlock the battery.
      • Flip and remove the battery from the computer.
      Ask FixBot
    2. Dell Precision M4700  Optical Drive Replacement: step 2, image 1 of 2 Dell Precision M4700  Optical Drive Replacement: step 2, image 2 of 2
      • Remove the two 3mm screws that secure the base cover to the computer with a Phillips #00 screwdriver.
      • Press the rubber tabs towards the rear of the computer to disengage the base cover.
      • Flip and remove the base cover from the computer.
      Ask FixBot
    3. Dell Precision M4700  Optical Drive Replacement: step 3, image 1 of 2 Dell Precision M4700  Optical Drive Replacement: step 3, image 2 of 2
      • Remove the 3mm screw that secures the optical drive to the computer with a Phillips #00 screwdriver.
      • Slide the optical drive out.
      Ask FixBot
Author
with
Dylan
385 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 16
Past 30 Days: 53
All Time: 986
