Up to 20% off select tools
Dell Precision M4600 KeyBoard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
62
All Time:
1,869
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Precision M4600 KeyBoard Replacement, Battery: step 1, image 1 of 2 Dell Precision M4600 KeyBoard Replacement, Battery: step 1, image 2 of 2
      • Slide the battery release latch into the unlock position.
      • Remove the battery from the system.
      Ask FixBot
    1. Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: step 2, image 1 of 3 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: step 2, image 2 of 3 Dell Precision M4600 KeyBoard Replacement, Keyboard Trim: step 2, image 3 of 3
      • Using a plastic scribe, pry under the keyboard trim to release it from the computer.
      • Work your way around the sides and bottom edge of the keyboard trim.
      • Lift up to remove the keyboard trim from the unit.
      Ask FixBot
    1. Dell Precision M4600 KeyBoard Replacement, KeyBoard: step 3, image 1 of 3 Dell Precision M4600 KeyBoard Replacement, KeyBoard: step 3, image 2 of 3 Dell Precision M4600 KeyBoard Replacement, KeyBoard: step 3, image 3 of 3
      • Remove the screws securing the keyboard in place.
      • Starting from the bottom of the keyboard, separate the keyboard from the system and turn the keyboard over.
      • Disconnect the keyboard data cable from the system board.
      Ask FixBot
    2. Dell Precision M4600 KeyBoard Replacement: step 4, image 1 of 3 Dell Precision M4600 KeyBoard Replacement: step 4, image 2 of 3 Dell Precision M4600 KeyBoard Replacement: step 4, image 3 of 3
      • Remove the keyboard.
      • Peel back the adhesive tape securing the keyboard data cable to the back of the keyboard.
      • Disconnect the keyboard data cable from the back of the keyboard.
      Ask FixBot
    3. Dell Precision M4600 KeyBoard Replacement: step 5, image 1 of 1
      • Peel the keyboard data cable away from the keyboard and remove.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 62
All Time: 1,869
