Up to 20% off select tools
Dell Precision M4400 Memory Module Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
10
Past 30 Days:
65
All Time:
951
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
    1. Dell Precision M4400 Memory Module Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latches to the open position. (The latches lock into place).
      • Grip the battery and slide it out of the battery bay.
      Ask FixBot
    1. Dell Precision M4400 Memory Module Replacement, Base Cover: step 2, image 1 of 1
      • Loosen the M2.5 x 5-mm captive screw.
      • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
      Ask FixBot
    1. Dell Precision M4400 Memory Module Replacement, Memory Module: step 3, image 1 of 1
      • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
      • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
      Ask FixBot
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 65
All Time: 951
