Dell Precision M4400 Hard Drive Replacement
    1. Dell Precision M4400 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Slide the battery release latches to the open position. (The latches lock into place).
      • Grip the battery and slide it out of the battery bay.
      Ask FixBot
    1. Dell Precision M4400 Hard Drive Replacement, Base Cover: step 2, image 1 of 1
      • Loosen the M2.5 x 5-mm captive screw.
      • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
      Ask FixBot
    1. Dell Precision M4400 Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 Dell Precision M4400 Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
      • NOTICE: When the hard drive is not in the computer, store it in protective anti-static packaging.
      • Remove the four M3 x 3-mm screws securing the hard drive. These screws are on the bottom of the base cover.
      • NOTE: If the bottom of the base cover is detached from the laptop, the four screws securing the hard drive are marked with an "H".
      • Slide the hard drive out of the computer.
      • Remove the face plate screw and then the face plate from the hard drive.
      Ask FixBot
Johnathan Hammond
46,347 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
What is on the slot on the opposite side of the DVD drive
It's missing and don't know what been
Removed
Bernard GUSTAVIS - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 73
All Time: 1,685
