Dell Precision M3800 Touch Pad Replacement
    1. Dell Precision M3800 Touch Pad Replacement, Back Cover: step 1, image 1 of 2 Dell Precision M3800 Touch Pad Replacement, Back Cover: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
      • iFixit’s magnetic project mat is great for keeping the screws in one place.
      • Lift up the silver cover from the back panel to reveal two screws.
      • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
      Ask FixBot
    2. Dell Precision M3800 Touch Pad Replacement: step 2, image 1 of 1
      • Use an opening tool to pry around the edges of the back panel to loosen the panel.
      • Remove the back panel.
      Ask FixBot
    1. Dell Precision M3800 Touch Pad Replacement, Battery: step 3, image 1 of 1
      • Disconnect the battery cable from the system board [1].
      • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
      • Lift the battery off the computer [2].
      Ask FixBot
    1. Dell Precision M3800 Touch Pad Replacement, Touch Pad: step 4, image 1 of 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: step 4, image 2 of 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: step 4, image 3 of 3
      • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
      Ask FixBot
    2. Dell Precision M3800 Touch Pad Replacement: step 5, image 1 of 2 Dell Precision M3800 Touch Pad Replacement: step 5, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
      Ask FixBot
    3. Dell Precision M3800 Touch Pad Replacement: step 6, image 1 of 1
      • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 54
All Time: 1,496
