Up to 20% off select tools
Dell Precision 7750 GPU Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
164
All Time:
564
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Very difficult
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace an old or faulty graphics card (GPU) in your Dell Precision 7750.
A GPU (graphics processing unit) is a piece of hardware that is designed to rapidly manipulate and display images, videos, and animations. Beyond graphics, GPUs excel at parallel processing.
Before using this guide, ensure that the issue you are experiencing cannot be solved via software, and that you have a means to read your M.2 drives (solid state drives) should something go wrong.
Make sure to power off your system using the shutdown option and unplug it from AC power prior to beginning the procedure.
Additionally, discharge static electricity from your body before touching internal components by touching an unpainted metal surface on the laptop chassis for at least five seconds.
    1. Dell Precision 7750 GPU Replacement, GPU: step 1, image 1 of 2 Dell Precision 7750 GPU Replacement, GPU: step 1, image 2 of 2
      • Make sure to power off your system using the shutdown option and unplug it from AC power prior to beginning the procedure.
      • Place the laptop face-down on a clean table.
      • Remove the screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. Dell Precision 7750 GPU Replacement: step 2, image 1 of 1
      • Run a plastic opening pick around the entire laptop until all clasps are disconnected.
      Ask FixBot
    3. Dell Precision 7750 GPU Replacement: step 3, image 1 of 2 Dell Precision 7750 GPU Replacement: step 3, image 2 of 2
      • Remove three screws from the battery using a Phillips #0 screwdriver.
      Ask FixBot
    4. Dell Precision 7750 GPU Replacement: step 4, image 1 of 1
      • Remove the battery cable by lifting up and away from the connector.
      Ask FixBot
    5. Dell Precision 7750 GPU Replacement: step 5, image 1 of 1
      • Lift and remove the battery from the laptop.
      Ask FixBot
    6. Dell Precision 7750 GPU Replacement: step 6, image 1 of 2 Dell Precision 7750 GPU Replacement: step 6, image 2 of 2
      • Detach the motherboard power connector.
      • Pull the connector in a straight motion to avoid component damage.
      Ask FixBot
    7. Dell Precision 7750 GPU Replacement: step 7, image 1 of 3 Dell Precision 7750 GPU Replacement: step 7, image 2 of 3 Dell Precision 7750 GPU Replacement: step 7, image 3 of 3
      • Detach the two fan connectors.
      • Pull the connectors in a straight motion to avoid component damage.
      Ask FixBot
    8. Dell Precision 7750 GPU Replacement: step 8, image 1 of 1
      • Carefully loosen eight screws in numbered order (1-8).
      • Loosening the screws in the numbered order ensures a uniform release of pressure for both the CPU and GPU.
      Ask FixBot
    9. Dell Precision 7750 GPU Replacement: step 9, image 1 of 1
      • Carefully remove the copper heatsink.
      Ask FixBot
    10. Dell Precision 7750 GPU Replacement: step 10, image 1 of 2 Dell Precision 7750 GPU Replacement: step 10, image 2 of 2
      • Remove eleven screws using a Phillips #0 screwdriver.
      Ask FixBot
    11. Dell Precision 7750 GPU Replacement: step 11, image 1 of 2 Dell Precision 7750 GPU Replacement: step 11, image 2 of 2
      • Remove the single screw from the Wi-Fi board using a Phillips #0 screwdriver.
      • Disconnect the white and black Wi-Fi antenna cables.
      Ask FixBot
    12. Dell Precision 7750 GPU Replacement: step 12, image 1 of 2 Dell Precision 7750 GPU Replacement: step 12, image 2 of 2
      • Remove the screw holding the solid state drive.
      • Pull the blue tab backwards to release the solid state drive.
      • Remove the solid state drive.
      Ask FixBot
    13. Dell Precision 7750 GPU Replacement: step 13, image 1 of 3 Dell Precision 7750 GPU Replacement: step 13, image 2 of 3 Dell Precision 7750 GPU Replacement: step 13, image 3 of 3
      • Remove six screws holding the M.2 drives using a Phillips #0 screwdriver.
      Ask FixBot
    14. Dell Precision 7750 GPU Replacement: step 14, image 1 of 1
      • Remove the metal heatsink by lifting by the screw side.
      • The thermal pad will break apart while taking the heatsink off; be careful not to lose parts of the pad or touch it.
      Ask FixBot
    15. Dell Precision 7750 GPU Replacement: step 15, image 1 of 2 Dell Precision 7750 GPU Replacement: step 15, image 2 of 2
      • Remove nine screws using a Phillips #1 screwdriver.
      Ask FixBot
    16. Dell Precision 7750 GPU Replacement: step 16, image 1 of 1
      • Disconnect the keyboard lighting ribbon cable.
      • Pull the ribbon cable directly away to avoid component damage.
      Ask FixBot
    17. Dell Precision 7750 GPU Replacement: step 17, image 1 of 1
      • Disconnect the keyboard ribbon cable.
      Ask FixBot
    18. Dell Precision 7750 GPU Replacement: step 18, image 1 of 1
      • Remove the antenna cables along the entire upper plastic housing.
      • Take extra care while removing these cables as they are thin and fragile.
      Ask FixBot
    19. Dell Precision 7750 GPU Replacement: step 19, image 1 of 1
      • Remove the upper plastic mount and place it somewhere until reassembly.
      Ask FixBot
    20. Dell Precision 7750 GPU Replacement: step 20, image 1 of 1
      • Disconnect the two ribbon cables from the upper motherboard housing.
      Ask FixBot
    21. Dell Precision 7750 GPU Replacement: step 21, image 1 of 2 Dell Precision 7750 GPU Replacement: step 21, image 2 of 2
      • Remove three screws from the GPU using a Phillips #0 screwdriver.
      • Take extra care not to unintentionally strip the screw heads, as these three screws are responsible for holding the GPU securely in place.
      Ask FixBot
    22. Dell Precision 7750 GPU Replacement: step 22, image 1 of 2 Dell Precision 7750 GPU Replacement: step 22, image 2 of 2
      • Remove the PCIe bridge screws using a Phillips #0 screwdriver.
      • Do not, under any circumstance touch the contacts on the PCIe bridge. Finger oils will ruin the contacts, signal quality will degrade significantly.
      Ask FixBot
    23. Dell Precision 7750 GPU Replacement: step 23, image 1 of 2 Dell Precision 7750 GPU Replacement: step 23, image 2 of 2
      • Disconnect the PW ribbon cable.
      Ask FixBot
    24. Dell Precision 7750 GPU Replacement: step 24, image 1 of 2 Dell Precision 7750 GPU Replacement: step 24, image 2 of 2
      • Un-clip the cable protection.
      • Disconnect the built-in screen connectors.
      Ask FixBot
    25. Dell Precision 7750 GPU Replacement: step 25, image 1 of 1
      • Disconnect the SD ribbon cable.
      Ask FixBot
    26. Dell Precision 7750 GPU Replacement: step 26, image 1 of 2 Dell Precision 7750 GPU Replacement: step 26, image 2 of 2
      • Disconnect the motherboard speaker cable.
      Ask FixBot
    27. Dell Precision 7750 GPU Replacement: step 27, image 1 of 1
      • Move the laptop chassis off the work area to isolate the motherboard and GPU board.
      Ask FixBot
    28. Dell Precision 7750 GPU Replacement: step 28, image 1 of 2 Dell Precision 7750 GPU Replacement: step 28, image 2 of 2
      • Invert the motherboard and GPU, then disconnect the GPU power cable.
      Ask FixBot
    29. Dell Precision 7750 GPU Replacement: step 29, image 1 of 1
      • Separate the GPU from the motherboard and place it on a clean surface.
      • At this point the procedure is complete. To install the new GPU, start here (Step 29) and follow these instructions in reverse order.
      • Steps 30-32 cover removing and applying thermal paste.
      • Apply the new thermal paste after reassembling the machine, but before mounting the heatsink (Step 9).
      Ask FixBot
    30. Dell Precision 7750 GPU Replacement: step 30, image 1 of 1
      • Use 70% or 90$ isopropyl alcohol (IPA) to remove the old thermal paste from the GPU.
      • I recommend using cotton swabs to clean the GPU. Drench the end of the swab with IPA, then rub the surface of the GPU until the majority of the old thermal paste is removed.
      • Take care not to rub off any of the capacitors at the edge of the GPU die.
      Ask FixBot
    31. Dell Precision 7750 GPU Replacement: step 31, image 1 of 1
      • A clean GPU should look like this.
      Ask FixBot
    32. Dell Precision 7750 GPU Replacement: step 32, image 1 of 2 Dell Precision 7750 GPU Replacement: step 32, image 2 of 2
      • GPU: apply new thermal paste in an "x" shape for best results, uniform spread will be applied later when you're screwing the copper heatsink back on.
      • CPU: apply new thermal paste as a "line" for maximum performance, uniform spread will be applied later when you're screwing the copper heatsink back on.
      • Once both the GPU and CPU have new thermal paste, carefully lay the copper heatsink back into place and view Step 8 for reassembly.
      • Step 8: tighten instead of loosen in numbered order (1-8), and make multiple rounds tightening slightly until all eight screws are tight.
      Ask FixBot
Author
with
Matias Montero
445 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 164
All Time: 564
