Up to 20% off select tools
Dell Precision 7710 Memory Module Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
74
All Time:
2,675
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips #0 Screwdriver
    5
    1. Dell Precision 7710 Memory Module Replacement, Battery Cover: step 1, image 1 of 1
      • Slide the release latch to unlock the battery cover [1].
      • Slide and lift the battery cover to remove it from the computer [2].
      Ask FixBot
    1. Dell Precision 7710 Memory Module Replacement, Battery: step 2, image 1 of 1
      • Slide the release latch to unlock the battery [1].
      • Lift and remove the battery from the computer [2].
      Ask FixBot
    1. Dell Precision 7710 Memory Module Replacement, Base Cover: step 3, image 1 of 1
      • Remove the screws that secure the base cover to the computer [1].
      • Slide and lift the base cover away from the computer [2].
      Ask FixBot
    1. Dell Precision 7710 Memory Module Replacement, KeyBoard: step 4, image 1 of 2 Dell Precision 7710 Memory Module Replacement, KeyBoard: step 4, image 2 of 2
      • Lift the tab and disconnect the 4 cables, one of the cables may be obstructed by the HDD, so you will need to unscrew/detatch the HDD tray first [1, 2].
      • Pry the keyboard trim starting from the bottom and work along the top edge and remove it from the computer.
      Ask FixBot
    2. Dell Precision 7710 Memory Module Replacement: step 5, image 1 of 1
      • Remove the screws that secure the keyboard to the computer [1].
      • Lift the front side and slide the keyboard to remove it away from the computer [2, 3].
      Ask FixBot
    1. Dell Precision 7710 Memory Module Replacement, Memory Module: step 6, image 1 of 1
      • Pry the retention clips away from the primary memory until it pops up.
      • Lift the primary memory and remove it from the computer.
      Ask FixBot
    2. Dell Precision 7710 Memory Module Replacement: step 7, image 1 of 1
      • Remove the screw that secures the memory shield to the computer [1].
      • Lift and remove the memory shield from the computer [2].
      • Pry the retention clips away from the memory module until it pops up [3].
      • Lift the memory module and remove it from the computer [4].
      Ask FixBot
2 other people completed this guide.
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 74
All Time: 2,675
