Dell Precision 7560 Wi-Fi Card Replacement
    1. Dell Precision 7560 Wi-Fi Card Replacement, Wi-Fi Card: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
      • The screws holding the back cover in place can not be removed.
      Ask FixBot
    2. Dell Precision 7560 Wi-Fi Card Replacement: step 2, image 1 of 2 Dell Precision 7560 Wi-Fi Card Replacement: step 2, image 2 of 2
      • Pry off the back cover using an iFixit opening tool.
      Ask FixBot
    3. Dell Precision 7560 Wi-Fi Card Replacement: step 3, image 1 of 1
      • Remove the 2 mm screw securing the wire cover using a Phillips #0 screwdriver.
      Ask FixBot
    4. Dell Precision 7560 Wi-Fi Card Replacement: step 4, image 1 of 1
      • Carefully detach the black and white wires from the Wi-Fi card.
      Ask FixBot
    5. Dell Precision 7560 Wi-Fi Card Replacement: step 5, image 1 of 1
      • Pull and lift the Wi-Fi card to remove it.
      Ask FixBot
Joshua Seo
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 97
All Time: 825
