Dell Precision 7560 Speaker Replacement
    1. Dell Precision 7560 Speaker Replacement, Battery: step 1, image 1 of 3 Dell Precision 7560 Speaker Replacement, Battery: step 1, image 2 of 3 Dell Precision 7560 Speaker Replacement, Battery: step 1, image 3 of 3
      • The screws holding the back cover in place can not be removed.
      • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
      • Remove the back cover by lifting at the corners.
      Ask FixBot
    2. Dell Precision 7560 Speaker Replacement: step 2, image 1 of 3 Dell Precision 7560 Speaker Replacement: step 2, image 2 of 3 Dell Precision 7560 Speaker Replacement: step 2, image 3 of 3
      • Unscrew and remove the five 2 mm screws that secure the battery.
      • Locate the battery connector.
      Ask FixBot
    3. Dell Precision 7560 Speaker Replacement: step 3, image 1 of 3 Dell Precision 7560 Speaker Replacement: step 3, image 2 of 3 Dell Precision 7560 Speaker Replacement: step 3, image 3 of 3
      • Pull the connector towards you to disconnect it.
      • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
      Ask FixBot
    1. Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): step 4, image 1 of 2 Dell Precision 7560 Speaker Replacement, Solid-State Drive (SSD): step 4, image 2 of 2
      • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
      Ask FixBot
    2. Dell Precision 7560 Speaker Replacement: step 5, image 1 of 2 Dell Precision 7560 Speaker Replacement: step 5, image 2 of 2
      • Remove the top cover of the Solid State Drive by lifting up from the corners.
      • Notice that the Solid State Drive is located underneath the cover.
      • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
      • With an appropriate replacement part, exchange the old SSD with a new one.
      Ask FixBot
    1. Dell Precision 7560 Speaker Replacement, Speaker: step 6, image 1 of 3 Dell Precision 7560 Speaker Replacement, Speaker: step 6, image 2 of 3 Dell Precision 7560 Speaker Replacement, Speaker: step 6, image 3 of 3
      • Loosen the eight captive screws that secure the fan assembly using a Phillips #0 screwdriver.
      • Lifting from the bottom, carefully remove the fan.
      Ask FixBot
    2. Dell Precision 7560 Speaker Replacement: step 7, image 1 of 3 Dell Precision 7560 Speaker Replacement: step 7, image 2 of 3 Dell Precision 7560 Speaker Replacement: step 7, image 3 of 3
      • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
      • Remove the metal overlay.
      • Disconnect the wires attached to the Wi-Fi card.
      • Remove the Wi-Fi card.
      Ask FixBot
    3. Dell Precision 7560 Speaker Replacement: step 8, image 1 of 2 Dell Precision 7560 Speaker Replacement: step 8, image 2 of 2
      • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
      • Remove, carefully and completely, any wires running over the frame.
      • Lift the metal frame.
      Ask FixBot
    4. Dell Precision 7560 Speaker Replacement: step 9, image 1 of 2 Dell Precision 7560 Speaker Replacement: step 9, image 2 of 2
      • Flip up the metal edge holding down the SD connection.
      • Gently pull to disconnect the metal connecting wire.
      Ask FixBot
    5. Dell Precision 7560 Speaker Replacement: step 10, image 1 of 3 Dell Precision 7560 Speaker Replacement: step 10, image 2 of 3 Dell Precision 7560 Speaker Replacement: step 10, image 3 of 3
      • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
      • Remove the metal cap.
      • Disconnect the wire bundle.
      Ask FixBot
    6. Dell Precision 7560 Speaker Replacement: step 11, image 1 of 3 Dell Precision 7560 Speaker Replacement: step 11, image 2 of 3 Dell Precision 7560 Speaker Replacement: step 11, image 3 of 3
      • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
      • Carefully remove the speaker wire from the motherboard.
      Ask FixBot
    7. Dell Precision 7560 Speaker Replacement: step 12, image 1 of 2 Dell Precision 7560 Speaker Replacement: step 12, image 2 of 2
      • Using both hands, carefully lift and remove the speaker.
      Ask FixBot
Neevia Vinod
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 77
All Time: 639
