Dell Precision 7560 Solid-State Drive (SSD) Replacement
    1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: step 1, image 1 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: step 1, image 2 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Battery: step 1, image 3 of 3
      • The screws holding the back cover in place can not be removed.
      • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
      • Remove the back cover by lifting at the corners.
      Ask FixBot
    2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 2, image 1 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 2, image 2 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 2, image 3 of 3
      • Unscrew and remove the five 2 mm screws that secure the battery.
      • Locate the battery connector.
      Ask FixBot
    3. Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 3, image 1 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 3, image 2 of 3 Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 3, image 3 of 3
      • Pull the connector towards you to disconnect it.
      • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
      Ask FixBot
    1. Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): step 4, image 1 of 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): step 4, image 2 of 2
      • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
      Ask FixBot
    2. Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 5, image 1 of 2 Dell Precision 7560 Solid-State Drive (SSD) Replacement: step 5, image 2 of 2
      • Remove the top cover of the Solid State Drive by lifting up from the corners.
      • Notice that the Solid State Drive is located underneath the cover.
      • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
      • With an appropriate replacement part, exchange the old SSD with a new one.
      Ask FixBot
Hector
315 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 135
All Time: 2,346
