Up to 20% off select tools
Dell Precision 7560 Screen Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
130
All Time:
2,624
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide provides step-by-step instructions for replacing the screen on your Dell Precision 7560 laptop, along with tips and precautions to ensure a successful replacement.
    1. Dell Precision 7560 Screen Replacement, Screen: step 1, image 1 of 3 Dell Precision 7560 Screen Replacement, Screen: step 1, image 2 of 3 Dell Precision 7560 Screen Replacement, Screen: step 1, image 3 of 3
      • Using an opener tool, pry open the bezel, following along the screen's perimeter.
      • Lightly pull from the corners to remove the bezel.
      Ask FixBot
    2. Dell Precision 7560 Screen Replacement: step 2, image 1 of 2 Dell Precision 7560 Screen Replacement: step 2, image 2 of 2
      • Use the Phillips #0 screwdriver to remove:
      • Two 2 mm screws from the top screen brackets.
      • Two 3 mm screws from the bottom screen brackets.
      • Once these screws are removed, you should be able to gently pry the laptop screen free.
      • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
      Ask FixBot
    3. Dell Precision 7560 Screen Replacement: step 3, image 1 of 3 Dell Precision 7560 Screen Replacement: step 3, image 2 of 3 Dell Precision 7560 Screen Replacement: step 3, image 3 of 3
      • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
      • Remove the blue tape that lies between the white tape and the video connector.
      • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
      Ask FixBot
Author
with
Laisha
232 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 130
All Time: 2,624
