Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement
    1. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 1 of 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 2 of 3 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement, NVMe Solid-State Drive (Expansion): step 1, image 3 of 3
      • The screws holding the back cover in place can not be removed.
      • Use a Phillips #0 screwdriver to loosen the eight 5 mm captive screws in the bottom cover.
      • Remove the back cover by lifting at the corners.
      Ask FixBot
    2. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 2, image 1 of 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 2, image 2 of 2
      • Use the Phillips #0 screwdriver to unscrew and remove the two 2 mm screws that secure the expansion NVMe SSD sticks.
      Ask FixBot
    3. Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 3, image 1 of 2 Dell Precision 7560 NVMe Solid-State Drive (Expansion) Replacement: step 3, image 2 of 2
      • Disconnect the left SSD stick by pulling its exposed end towards you.
      • Repeat the same procedure to the right SSD stick.
      Ask FixBot
Hector
315 Reputation
2 Guides authored
1 Guide Comment
This is not for RAM this is for the SSD upgrades.
Kurtis - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 77
All Time: 1,232
