Up to 20% off select tools
Dell Precision 7560 Keyboard Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
146
All Time:
2,798
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The guide shows how to remove the keyboard from a Dell Precision 7560. The keyboard is a core component of the computer, so keeping on top of its maintenance is vital. If the issue with the keyboard isn't merely debris keeping a key from functioning, then this guide will assist you in replacing the keyboard entirely.
    1. Dell Precision 7560 Keyboard Replacement, Battery: step 1, image 1 of 3 Dell Precision 7560 Keyboard Replacement, Battery: step 1, image 2 of 3 Dell Precision 7560 Keyboard Replacement, Battery: step 1, image 3 of 3
      • The screws holding the back cover in place can not be removed.
      • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
      • Remove the back cover by lifting at the corners.
      Ask FixBot
    2. Dell Precision 7560 Keyboard Replacement: step 2, image 1 of 3 Dell Precision 7560 Keyboard Replacement: step 2, image 2 of 3 Dell Precision 7560 Keyboard Replacement: step 2, image 3 of 3
      • Unscrew and remove the five 2 mm screws that secure the battery.
      • Locate the battery connector.
      Ask FixBot
    3. Dell Precision 7560 Keyboard Replacement: step 3, image 1 of 3 Dell Precision 7560 Keyboard Replacement: step 3, image 2 of 3 Dell Precision 7560 Keyboard Replacement: step 3, image 3 of 3
      • Pull the connector towards you to disconnect it.
      • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
      Ask FixBot
    1. Dell Precision 7560 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Dell Precision 7560 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Dell Precision 7560 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
      • Pulling from the tab, carefully remove the connector.
      Ask FixBot
    2. Dell Precision 7560 Keyboard Replacement: step 5, image 1 of 3 Dell Precision 7560 Keyboard Replacement: step 5, image 2 of 3 Dell Precision 7560 Keyboard Replacement: step 5, image 3 of 3
      • Turn the device over and open the screen to expose the keyboard.
      • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
      Ask FixBot
    3. Dell Precision 7560 Keyboard Replacement: step 6, image 1 of 3 Dell Precision 7560 Keyboard Replacement: step 6, image 2 of 3 Dell Precision 7560 Keyboard Replacement: step 6, image 3 of 3
      • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
      • Carefully remove the keyboard from the device.
      Ask FixBot
2 other people completed this guide.
Author
with
Jack Allred
354 Reputation
2 Guides authored
1 Guide Comment
Guide is close, but not completely correct. Just need a little more attention to detail.
Barry Todd - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 146
All Time: 2,798
