Up to 20% off select tools
Dell Precision 7510 Memory Module Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
87
All Time:
12,386
Comments: 6
5 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Module.
    1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: step 1, image 1 of 1
      • Slide the release latch to unlock the battery cover.
      • Slide and lift the battery cover to remove it from the computer.
      Ask FixBot
    1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: step 2, image 1 of 1
      Ask FixBot
    1. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: step 3, image 1 of 1
      • Remove the screws that secure the hard drive to the computer.
      • Lift the hard-drive latch to the unlock position.
      • Slide and lift the hard drive from the computer.
      Ask FixBot
    2. Dell Precision 7510 Memory Module Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
      Ask FixBot
    1. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: step 5, image 1 of 1
      • Peel the tape to access the cable.
      • Lift the tab and disconnect the keyboard cables from the system board.
      Ask FixBot
    2. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: step 6, image 1 of 1
      • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
      • Remove the screws that secure the keyboard to the computer.
      • Lift the front side and slide the keyboard to remove it away from the computer.
      Ask FixBot
    1. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: step 7, image 1 of 1
      • Remove the screw that secures the memory shield to the computer.
      • Lift and remove the memory shield from the computer.
      • Pry the retention clips away from the memory module until it pops up.
      • Lift the memory module and remove it from the computer.
      Ask FixBot
    2. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: step 8, image 1 of 1
      • Pry the retention clips away from the primary memory until it pops up.
      • Lift the primary memory and remove it from the computer.
      Ask FixBot
Finish Line
2 other people completed this guide.
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 87
All Time: 12,386
