Up to 20% off select tools
Dell Precision 7510 KeyBoard Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
13
Past 30 Days:
78
All Time:
5,057
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Keyboard.
    1. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: step 1, image 1 of 1
      • Slide the release latch to unlock the battery cover.
      • Slide and lift the battery cover to remove it from the computer.
      Ask FixBot
    1. Dell Precision 7510 KeyBoard Replacement, Removing the Battery Cover: step 2, image 1 of 1
      Ask FixBot
    1. Dell Precision 7510 KeyBoard Replacement, Removing the Hard Drive: step 3, image 1 of 1
      • Remove the screws that secure the hard drive to the computer.
      • Lift the hard-drive latch to the unlock position.
      • Slide and lift the hard drive from the computer.
      Ask FixBot
    2. Dell Precision 7510 KeyBoard Replacement, Remove the Screws: step 4, image 1 of 1
      • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
      Ask FixBot
    1. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard Cables: step 5, image 1 of 1
      • Peel the tape to access the cable.
      • Lift the tab and disconnect the keyboard cables from the system board.
      Ask FixBot
    2. Dell Precision 7510 KeyBoard Replacement, Removing the Keyboard: step 6, image 1 of 1
      • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
      • Remove the screws that secure the keyboard to the computer.
      • Lift the front side and slide the keyboard to remove it away from the computer.
      Ask FixBot
Finish Line
4 other people completed this guide.
Author
with
Johnathan Hammond
46,425 Reputation
408 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
1 Guide Comment
Einfach und verständlich geschrieben. Habs ohne Probleme geschafft :-)
Nur hab ich mich gefragt: Wozu Schritt 4?! Der ist zum Entfernen der Tastatur gar nicht nötig.
Wer also nur die Tastatur wechseln möchte, kann von 3 gleich zu 5 springen.
Danke für die Anleitung.
Hat mir sehr geholfen.
f_siman - Reply Share
Past 24 Hours: 4
Past 7 Days: 13
Past 30 Days: 78
All Time: 5,057
